3 Replies Latest reply on Mar 20, 2011 1:08 AM by sasientry
    Resize image
    sasientry Level 1
      Hi Guys,
      Please help me how to resize image in photoshop
      square images only
      when i have above 3000 pixels image must resize 3000
      when i have pixels between 2999 px to 2501 px i want to resize 2500 px
      when i have pixels between 2499 px to 2001 px i want to resize 2000 px
      when i have pixels between 1999 px to 1501 px i want to resize 1500 px
      when i have pixels between 1499 px to 1001 px i want to resize 1000 px
      when i have pixels between 999 px to 801 px i want to resize 800 px
      don't change image when have 3000,2500,2000,1500,1000,800 pixels
        • 1. Re: Resize image
          Looks like you have the logic for what you want to do. The only thing you did not covered is when square and size is less then 800 pixels.
          If width  == hight  then
             case  width gt 3000 resize to 3000
             case  width  gt 2500 & lt 3000  resize to 2500
             case  width  gt 2000 & lt 2500  resize to 2000
             case width lt 800 forget about it
          else not square forget about it
          end else
          • 2. Re: Resize image
            Muppet Mark-QAl63s Level 4
            I had all but the briefest of looks at this and I don't think you can use switch/case like that…? I think 'case' evaluates a variable not an expression… Some one will tell me if Im wrong as normal… You could other wise just chain if/else if… OK had 10 minutes a possible route could be some thing like this using 'case' where you do some math first so case gets a value passed to it… Do check my math thou… I don't see any issue with calling a resize on images that match your value… nothing will happen will it? Oh yeah I was working in pixels as always…
            #target photoshop
            var doc = app.activeDocument;
            var docW = doc.width;
            var docH = doc.height;
            if (docW == docH && docW > 800) {
                 switch(Math.floor(docW/500)) {
                      case 5 : doc.resizeImage(2500,undefined,undefined,ResampleMethod.BICUBICSMOOTHER); break;
                      case 4 : doc.resizeImage(2000,undefined,undefined,ResampleMethod.BICUBICSMOOTHER); break;
                      case 3 : doc.resizeImage(1500,undefined,undefined,ResampleMethod.BICUBICSMOOTHER); break;
                      case 2 : doc.resizeImage(1000,undefined,undefined,ResampleMethod.BICUBICSMOOTHER); break;
                      case 1 : doc.resizeImage(800,undefined,undefined,ResampleMethod.BICUBICSMOOTHER); break;
                      default : doc.resizeImage(3000,undefined,undefined,ResampleMethod.BICUBICSMOOTHER);
            • 3. Re: Resize image
              sasientry Level 1
              Thanks Muppet Mark,
              Thanks for clear this
              pls give me another script also
              canvas size for 3/4 asper ratio width is 3 ratio height is 4 ratio
              after run this  i have to resize height pixels
              when i have pixels between 1499 px to 1101 px i want to resize 1000 px
              don't change image when have 3000,2500,2000,1500,1100 pixels
              thanks
