0 Replies Latest reply on Mar 19, 2011 1:11 AM by itsvikasjindal
    Help - Passing complextype arguement to WebService
    itsvikasjindal
      I'm trying to pass a complex type into a web service request.
      <definitions xmlns:http="http://schemas.xmlsoap.org/wsdl/http/" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/" xmlns:s="http://www.w3.org/2001/XMLSchema" xmlns:s0="CEM_Services_HTTP_BI_Service" xmlns:tns1="dsws.businessobjects.com" targetNamespace="CEM_Services_HTTP_BI_Service" xmlns="http://schemas.xmlsoap.org/wsdl/" name="BIServices">
      - <s:simpleType name="Operator">
      - <s:restriction base="s:string">
        <s:enumeration value="EQUAL" />
        <s:enumeration value="GREATER" />
        <s:enumeration value="GREATER_OR_EQUAL" />
        <s:enumeration value="LESS" />
        <s:enumeration value="LESS_OR_EQUAL" />
        <s:enumeration value="NOT_EQUAL" />
        <s:enumeration value="INLIST" />
        <s:enumeration value="NOT_INLIST" />
        </s:restriction>
        </s:simpleType>
      - <s:complexType name="FilterCondition">
      - <s:sequence>
        <s:element name="value" type="s:string" />
        <s:element name="operator" type="s0:Operator" />
        </s:sequence>
        </s:complexType>
      </s:element>
      - <s:element name="GetReportBlock_CEM_Service_HTTP_DL_Per_Server">
      - <s:complexType>
      - <s:sequence>
        <s:element name="login" type="s:string" minOccurs="0" nillable="true" />
        <s:element name="password" type="s:string" minOccurs="0" nillable="true" />
        <s:element name="Web_Server" type="s0:FilterCondition" minOccurs="0" maxOccurs="unbounded" nillable="true" />
        <s:element name="resetState" type="s:boolean" minOccurs="0" nillable="true" />
        <s:element name="refresh" type="s:boolean" minOccurs="0" nillable="true" />
        <s:element name="getFromLatestDocumentInstance" type="s:boolean" minOccurs="0" nillable="true" />
        <s:element name="getFromUserInstance" type="s:boolean" minOccurs="0" nillable="true" />
        <s:element name="turnOutputToVTable" type="s:boolean" minOccurs="0" nillable="true" />
        </s:sequence>
        </s:complexType>
        </s:element>
      Here is the code which written in Flex;
        <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      <s:WebService id="serviceID" wsdl="http://hostname:8080/dswsbobje/qaawsservices/biws?wsdl=1&cuid=FnB4g03HzwwAxTQAALBLF0UAABFD 6L5R"
        endpointURI="http://hostname:8080/dswsbobje/qaawsservices/queryasaservice?&cuid=FnB4g03HzwwAxTQAALBLF0U AABFD6L5R&authType=secEnterprise&locale=en&timeout=60&ConvertAnyType=true"
        service="CEM_Services_HTTP_BI_Service" port="BIServicesSoap" makeObjectsBindable="true" >
      <s:operation  name="GetReportBlock_CEM_Service_HTTP_DL_Per_Server"
      resultFormat="e4x"
        result="showResult(event);"
        fault="genericFaultHandler(event)"
      </s:operation>
      </fx:Declarations>
              <fx:Script>
                      <![CDATA[
                     private function send_data():void {
                     host = new Array( ["www.music.com","INLIST"]);
                     serviceID.GetReportBlock_CEM_Service_HTTP_DL_Per_Server("administrator", "password", host, true, false, true, true, true);
      But When I capture the http request dump, its not as expected:
      <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:s="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
        <SOAP-ENV:Body>
          <s0:GetReportBlock_CEM_Service_HTTP_DL_Per_Server xmlns:s0="CEM_Services_HTTP_BI_Service">
            <s0:login>administrator</s0:login>
            <s0:password>Tekelec1</s0:password>
            <s0:Web_Server>
              <s0:value>www.music.com,INLIST</s0:value>
              <s0:operator>www.music.com,INLIST</s0:operator>
            </s0:Web_Server>
            <s0:resetState>true</s0:resetState>
            <s0:refresh>false</s0:refresh>
            <s0:getFromLatestDocumentInstance>true</s0:getFromLatestDocumentInstance>
            <s0:getFromUserInstance>true</s0:getFromUserInstance>
            <s0:turnOutputToVTable>true</s0:turnOutputToVTable>
          </s0:GetReportBlock_CEM_Service_HTTP_DL_Per_Server>
        </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>
      I tried to pass the paramter value in WebService tag itself:
      <s:request>
      <login>administrator</login>
      <password>Tekelec1</password>
      <Web_Server>
      <value>www.music.com</value>
      <operator>INLIST</operator>
      </Web_Server>
      <resetState>true</resetState>
      <refresh>false</refresh>
      <getFromLatestDocumentInstance>true</getFromLatestDocumentInstance>
      <getFromUserInstance>true</getFromUserInstance>
      <turnOutputToVTable>true</turnOutputToVTable>
      </s:request>
      <s:request>
      <Web_Server>www.music.com, INLIST</Web_Server>
      </s:request>
      But it again did not work. Actually WebService always pass same values to Web_Server.value and Web_Server.Operator tags. But my requirement is to pass website address in Web_Server.value tag and "INLIST" in Web_Server.Operator tag.
      Can somebody help in resolving this issue??
      Thanks in advance,
      Vikas Jindal
