1 Reply Latest reply on Mar 21, 2011 4:30 AM by samschauhan
    File problem
    Ladislav Navrátil
      Hi all,
      i would like to ask for some informations about works with files.
      User of my application should select files from his computer(probably by file.browseForOpenMultiple), than i would like to copy selected files toapplicationStorageDirectory.
      But when i am trying do that by:
      var file:File = new File();
      file.addEventListener(FileListEvent.SELECT_MULTIPLE, onSelected);
      file.browseForOpenMultiple("something");
      function onSelected(event:FileListEvent):void{
           var destinationFile:File = File.applicationStorageDirectory;
           for(var i:Number = 0; i < event.files.length; i++){
                event.files[i].copyTo(destinationFile);
      it doesnt works.
      after running previously code, flash builder made an error:
      Error: Error #3012: Cannot delete file or directory.
      at flash.filesystem::File/copyTo()
      Thanks for your help.
        • 1. Re: File problem
          samschauhan
          The code you have shared will work when you want to copy a directory.
          For copying a file you have to make sure that destinationFile is a file.
          This works:
                          var destinationFile:File=File.applicationStorageDirectory.resolvePath("test.txt");
                          for (var i:Number=0; i < event.files.length; i++)
                              event.files[i].copyTo(destinationFile,true);
          Regards,
          SAM
