3 Replies Latest reply on Mar 21, 2011 7:52 PM by JMResler
    SWFLoading problem...
    JMResler
      Hi All,
          I have an application that loads and unloads multiple swf files dependent upon the role of the user.
      When I login to the app for the first time the web service calls all work fine. When I logout, I call the
      method SWFLoader.unloadAndStop();
      When the next user logs in, I load the dependent SWF (maybe reload the same one used previously)
      and proceed from there. The second time I login, clicking on the UI invokes type coercion errors.
      I would think these errors would show up with the first load but they do not. Does anyone have any
      useful suggestions? Thanks in advance.
      BTW, thanks to a guy whose login I can't recall but who solved a problem perfectly. Hopefully you
      know who you are.
      - JR
        • 1. Re: SWFLoading problem...
          Codeflayer
          Hi there,
          your description is a bit vague. It'd be helpful to have a stack trace. The
          first place I'd look is at the outside data you're trying to load. Is there
          some data that gets loaded from outside when the user logs in a second time?
          Good luck!
          • 2. Re: SWFLoading problem...
            Flex harUI Adobe Employee
            Probably the data types are registered on the first load and not
            re-registered on the second load then the data types cannot be converted.
            Try linking the data types into the main app.
            • 3. Re: SWFLoading problem...
              JMResler Level 1
              Maybe the code will help and how do I link datatypes into the main app?
              <fx:Declarations>
                   <userservice:Userservice id="userService"
                                                        useProxy="false"
                                                        fault="loginFaultHandler(event)"
                                                        result="loginHandler(event)"
                                                        showBusyCursor="true">
                   </userservice:Userservice>
              </fx:Declarations>
                   private function loginHandler(event:ResultEvent) : void
                        user = new User();
                        if (event != null)
                             if (event.result.Id != 0 && event.result.UserType != "None")
                                  isLoggedIn = true;
                                  user.Id = event.result.Id;
                                  user.UserId = event.result.UserId;
                                  user.Name = event.result.Name;
                                  user.UserType = event.result.UserType;
                                  user.Token = event.result.Token;
                                  loginAttempts = 0;
                                  generalPurposeLabel.text = event.result.Name;
                                  userIDInput.text = "";
                                  passwordInput.text = "";
                                  currentState = 'logoutState';
                                  // dispatch login event here.
                                  var loginEvent:LoginEvent = new LoginEvent(user,loader);
                                  loginEvent.dispatch();
                            else
                             { // we had an invalid login
                                  generalPurposeLabel.text = loginFailedMessage;
                             passwordLabel.text = "";
                    private function login(event:Event) : void
                        // are we already logged in?
                        if (currentState == "loginState")
                             // increment the login attempts
                             loginAttempts++;
                             if (loginAttempts >= maxLoginAttempts)
                                  // send locked out message
                                  generalPurposeLabel.text = exceededLoginCountMessage;
                                  // disable further attempts
                                  logBtn.enabled = false;
                                  userIDInput.enabled = false;
                                  passwordInput.enabled = false;
                                  return;
                                  // limited input validation
                                  // TODO - plugin validator later
                             if (  userIDInput.text.length == 0 ||
                                  passwordInput.text.length == 0)
                                  Alert.show("Please enter both user name\n and password to login.", "Login Failed", Alert.OK);
                                  generalPurposeLabel.text = "";
                                  return;
                          try {
                                  userService.Authenticate(userIDInput.text, passwordInput.text);
                                  // userService.Authenticate.send();
                             } catch (error:Error) {
                                       Alert.show(error.toString(), "Web Service Connection Fault", Alert.OK);
                        else if (currentState == "logoutState")
                             logoutHandler(event);
                   private function logoutHandler(event:Event) : void
                        currentState = "loginState";
                        loginAttempts = 0;
                        user.invalidateUser();
                        var logoutEvent:LogoutEvent = new LogoutEvent(user.Token, loader);
                        logoutEvent.dispatch();
