5 Replies Latest reply on Mar 20, 2011 1:26 PM by John T Smith
    Why would a 21 minute video only show up as a partial clip in project panel and timeline?
    met5699
      When I import uncompressed AVI file (21 minutes long) into project panel, it shows up as 4 seconds and 18 frames in length. Clip shows the full 21 minutes long in bridge and windows media player. I have rebooted computer and checked for updates. Also shows up as a shorter clip in After Effects. Any ideas?
        • 1. Re: Why would a 21 minute video only show up as a partial clip in project panel and timeline?
          the_wine_snob Level 9
          Welcome to the forum.
          Where did the AVI Clip come from?
          Does G-Spot show the full Duration of that Clip?
          I've seen this happen with some converted AVI files, and it appears that the Duration flag in the header is not set properly, or is missed by PrPro.
          • 2. Re: Why would a 21 minute video only show up as a partial clip in project panel and timeline?
            met5699 Level 1
            Thanks for helping Bill.
            The clip came from my Church service I recorded this morning using vidblaster (I am definitely not a professional). I analyzed the file in g spot. Note in container said 28.5 GB unneeded bytes at end of file. Do you know if there is any way of fixing this file at this point?
            • 3. Re: Why would a 21 minute video only show up as a partial clip in project panel and timeline?
              Colin Brougham Level 6
              Forget GSpot; get MediaInfo, load the clip into it, and switch the view into Text mode. Copy and paste the results here.
              Does the clip only import about 4 minutes of video, or does it only say that it's 4 minutes of video? In other words, if you drop the clip in a sequence, is the clip 4 minutes or 21 minutes?
              • 4. Re: Why would a 21 minute video only show up as a partial clip in project panel and timeline?
                met5699 Level 1
                General
                Complete name                    : E:\3_20\1st.avi
                Format                           : AVI
                Format/Info                      : Audio Video Interleave
                Format profile                   : OpenDML
                File size                        : 33.5 GiB
                Duration                         : 21mn 33s
                Overall bit rate                 : 223 Mbps
                Video
                Format                           : RGB
                Codec ID                         : 0x00000000
                Codec ID/Info                    : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
                Duration                         : 21mn 33s
                Bit rate                         : 221 Mbps
                Width                            : 640 pixels
                Height                           : 480 pixels
                Display aspect ratio             : 4:3
                Frame rate                       : 30.000 fps
                Bit depth                        : 8 bits
                Bits/(Pixel*Frame)               : 23.999
                Stream size                      : 33.3 GiB (99%)
                Audio
                Format                           : PCM
                Format settings, Endianness      : Little
                Format settings, Sign            : Signed
                Codec ID                         : 1
                Codec ID/Hint                    : Microsoft
                Duration                         : 21mn 32s
                Bit rate mode                    : Constant
                Bit rate                         : 1 411.2 Kbps
                Channel(s)                       : 2 channels
                Sampling rate                    : 44.1 KHz
                Bit depth                        : 16 bits
                Stream size                      : 217 MiB (1%)
                Interleave, duration             : 250 ms (7.50 video frames)
                Yes the clip itself is only as long as the info in the project panel when I drag it to the timeline, about 4 minutes
                • 5. Re: Why would a 21 minute video only show up as a partial clip in project panel and timeline?
                  Search the forum for
                  Little Endian
                  I'm not 100% sure, but I **think** I've seen a past message or two about problems
