2 Replies Latest reply on Mar 21, 2011 2:31 AM by Muppet Mark-QAl63s
    Saving folder option
    sasientry Level 1
      Hi Guys,
      where i will take images i want to create new folder there named tif
      after saving options are
      tiff format LZW,Interleaved,IBM pc and also tick save transperancy when layered file
        • 1. Re: Saving folder option
          Muppet Mark-QAl63s Level 4
          To help with you first question
          // Set a variable to a 'folder object' using string for the path
          var saveFolder = Folder('~/Desktop/Save in here');
          // Check if it exists if not then make it
          if (!saveFolder.exists) saveFolder.create();
          In your case you could either hard code the path or retrieve it/construct it from a file at run time…
          • 2. Re: Saving folder option
            And to help with your second question most users here in the forum have functions for using the document 'save as' command… Like this…
            // Save file as TIFF function
            function saveAsTIFF(saveFile) {
            opts = new TiffSaveOptions();
            opts.alphaChannels = false;
            opts.byteOrder = ByteOrder.IBM;
            opts.embedColorProfile = true;
            opts.imageCompression = TIFFEncoding.TIFFLZW;
            opts.interleaveChannels = true;
            opts.layers = false;
            opts.spotColors = false;
            opts.transparency = true;
            activeDocument.saveAs(saveFile,opts,true,Extension.LOWERCASE);
            'saveFile' should be a 'file object' passed as argument to the function. There are additional options for tiff so you should look them up in the scripting guide…
