1 Reply Latest reply on Jul 25, 2006 8:55 PM by Salccnpp
    Consumming java webservices in coldfusion
    okoth
      could somebody show me how to consume this webservice from within coldfusion?
      " http://www.ripedev.com/webservices/ZipCode.asmx?WSDL"
      right now I invoke it as follows:
      <cfinvoke
      webservice=" http://www.ripedev.com/webservices/ZipCode.asmx?WSDL"
      method="ZipCodeToCityState" ZipCode="12210" returnvariable="returnedText" >
      </cfinvoke>
      <cfoutput>
      #arraylen(variables.returnedText)#
      </cfoutput>
      And this is what i get
      com.ripedev.xsd.ZipCodeResults_xsd.ArrayOfAnyType@aaa1d576 .
      This actually has no meaning to me.
      amos
        • 1. Re: Consumming java webservices in coldfusion
          Salccnpp
          I'm just learning how to consume webservice stuff but this should help as I got a result. See my code snippet below.
          Basically I did some cfdumps to see what the objects look like. This is from an empirical view as I don't understand yet. The object comes back with methods. You then use those methods to get values. I chose to use the getAnyType method. I did this as I used another tool, soapscope from www.mindreef.com (30 day eval) which really simplifies how to call webservices. It's worth the cost.
          Basically I invoked the service via soapscope and looked at the returned xml.
          It looked like:
          <soap:Envelope
          xmlns:soap=" http://schemas.xmlsoap.org/soap/envelope/"
          xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance"
          xmlns:xsd=" http://www.w3.org/2001/XMLSchema">
          <soap:Body>
          <ZipCodeToCityStateResponse xmlns=" http://ripedev.com/xsd/ZipCodeResults.xsd">
          <ZipCodeToCityStateResult>
          <anyType xsi:type="xsd:string">Albany, NY</anyType>
          </ZipCodeToCityStateResult>
          </ZipCodeToCityStateResponse>
          </soap:Body>
          </soap:Envelope>
          Note that the result was in a value of anyType. Thus I picked getAnyType method
          I hope this helps ya but I'm still quite a newbie to this. This link help me understand a little more about webservice http://tutorial292.easycfm.com/
          Zip test WS Object
          object of com.ripedev.xsd.ZipCodeResults_xsd.ArrayOfAnyType
          Methods hashCode (returns int)
          equals (returns boolean)
          getSerializer (returns interface org.apache.axis.encoding.Serializer)
          getDeserializer (returns interface org.apache.axis.encoding.Deserializer)
          getTypeDesc (returns org.apache.axis.description.TypeDesc)
          getAnyType (returns java.lang.Object)
          getAnyType (returns [Ljava.lang.Object;)
          setAnyType (returns void)
          getClass (returns java.lang.Class)
          wait (returns void)
          wait (returns void)
          wait (returns void)
          notify (returns void)
          notifyAll (returns void)
          toString (returns java.lang.String)
          Breaking down the object
          array
          1 Albany, NY
