2 Replies Latest reply on Jun 12, 2007 12:00 PM by Digic
    URLLoader problem w/relative URLs
    Digic Level 1
      URLLoader doesn't seem to work with certain forms of URLs. I've got it to work ok with URLs in the following forms:
      http://www.domain.com/path/data.xml
      data.xml
      ../../dir/data.xml
      But does not these (and I made sure that they are valid paths):
      /home/www/domain/path/data.xml
      ../../../dir/dir/data.xml
      It's interesting that it works with the last example in the first set but not the last example in the second set since they're in the same form except the latter goes back one more level. I would like to use an explicit path like /path/data.xml but URLLoader doesn't seem to like this.
      Is this a known bug in URLLoader? Is there a workaround?
