6 Replies Latest reply on Mar 21, 2011 8:56 AM by plarts
    CF8 and ACCESS 2007 and cfoutput
    plarts Level 1
      I installed the required ODBC driver for Access 2007 on CF8. Fine.
      I declare a new DATASOURCE if CF (socket ODBC) fine
      I write a CF file with a simple query (select) , the cfouput
      Almost fine,
      except that : the displayed data is encountered by the #  (like the called variable)
      Here the code  :
      <cfoutput>
      <cfquery name="liste_ad" datasource="test_r4">
           select * from Descriptif_vehicules
      </cfquery>
      <cfloop query="liste_ad">
           #source_disponibilite#<br>
      </cfloop>
      </cfoutput>
      here is the Display : (a single record in the base)
      #http://www.avto.net/_AVTO/ad.asp?ID=4418041&show=1#
      It has to be :
      which is the data in the Access (.accdb file)  DB
      How to get reed of the 2 x #    ???
      Thanks for any help ?
      Pierre.
