2 Replies Latest reply on Mar 21, 2011 4:03 PM by tjay99
    States and XML mix
    tjay99 Level 1
      Hi Everyone,
      I am hoping someone can help, as this code is now above my skill level.
      Currently I have these two mxml files running fine:
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" height="100%" horizontalAlign="center" horizontalCenter="0" verticalScrollPolicy="off" horizontalScrollPolicy="off" scroll="false" layout="absolute" applicationComplete="init()" focusRect="false" showStatusBar="false" showTitleBar="false" showFlexChrome="false" borderStyle="none" creationComplete="readXMLContent();">
      <mx:Script>
          <![CDATA[
      private function init():void
          systemManager.stage.displayState=flash.display.StageDisplayState.FULL_SCREEN_INTERACTIVE
      </mx:Script>
          <mx:Script>
              <![CDATA[
                  import mx.controls.Alert;
                  import mx.utils.ObjectProxy;
                  import mx.rpc.events.ResultEvent;
                  [Bindable]
                  public var xml:XML = new XML();
                  private var userManualObj:ObjectProxy;
                  private function loadModelData(event:ResultEvent):void
                      userManualObj=event.result.UserManual;
                  private function readXMLContent():void
                      var reportDir:File = File.userDirectory.resolvePath("myassets");
                      var xmlFile:File;
                      var fileStream:FileStream = new FileStream();
                      xmlFile = reportDir.resolvePath("screen.xml");
                      if(xmlFile.exists && xmlFile.size > 0)// Checking if the UserGuide.xml file already exists and the file is not empty
                      var stream:FileStream = new FileStream();
                  //var xml:XML = new XML();
                      stream.open(xmlFile, FileMode.READ);
                      xml = XML(stream.readUTFBytes(stream.bytesAvailable));
                      var strXml:String = xml.toXMLString();
                      //Alert.show(strXml);
                      //trace(strXml);
                      stream.close();
          </mx:Script>
               <mx:XMLListCollection id="xmlCollection" source="{xml.content.item.file}" />
                   <mx:TileList
                       height="100%"
                       width="100%"
              id="tileListCtrl"
              dataProvider="{xmlCollection}"
              itemRenderer="ImageRenderer"
              columnCount="1"
              rowCount="1"
              scroll="false"
              borderStyle="none" themeColor="#000000" borderColor="#ff0000"
               paddingBottom="0"
                 paddingLeft="0"
                  paddingRight="0"
                   paddingTop="0"
      </mx:WindowedApplication>
      <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml" verticalScrollPolicy="off" horizontalScrollPolicy="off" borderStyle="none" scroll="false" backgroundColor="#000000" horizontalAlign="center" initialize="vbox1_initializeHandler(event);">
          <mx:Script>
              <![CDATA[
              import mx.events.FlexEvent;
              protected function vbox1_initializeHandler(event:FlexEvent):void
      //images directory
      var imagePath:File;
      //image name from xml file
      imagePath = reportDir.resolvePath(data.@showimage);
      // we got the complete system path
      myImage.source = imagePath.url;
      //when we trace the path looks like
      //file:///C:/Users/Administrator/Desktop/myassets/myImage.JPG
          </mx:Script>
          <mx:Image id="myImage" width="100%" height="100%" verticalCenter="0" horizontalCenter="0" horizontalAlign="center" verticalAlign="middle"/>
      </mx:VBox>
      But I need to add the following functionality to determine whether <mx:Image> or <mx.VideoDisplay> needs to be used:
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
          currentState="videoState" creationComplete="init()">
          <mx:Script>
              <![CDATA[
                      fileSystemTree.directory = File.desktopDirectory;
                  private function browseDir(e:Event):void
                      var dir:File = new File();
                      dir.browseForDirectory("Select directory");
                      dir.addEventListener(Event.SELECT, onDirSelect);
                  private function onDirSelect(event:Event):void
                      fileSystemTree.directory = event.currentTarget as File;
                  private function onChange(e:Event):void
                      var file:File = e.currentTarget.selectedItem as File;
                      if(!file.isDirectory)
                          var viewer:Object;
                          switch(file.extension.toLowerCase())
                              case "flv":
                                  currentState = "videoState";
                                  viewer = videoDisplay;
                                  break;
                              case "png":
                              case "jpg":
                                  currentState = "imageState";
                                  viewer = image;
                                  break;
                              default:
                                  Alert.show("Unsupported file " + file.nativePath, "Error");
                                  return;
                          viewer.source = file.url;
          </mx:Script>
          <mx:HDividedBox width="100%" height="100%" paddingLeft="10" paddingRight="10" paddingBottom="10" paddingTop="10">
              <mx:VBox width="200" height="100%">
                  <mx:Button label="Change Directory" click="browseDir(event)" />
                  <mx:FileSystemTree id="fileSystemTree" width="100%" height="100%"
                      change="onChange(event)" />
              </mx:VBox>
              <mx:Canvas width="100%" height="100%" id="content" />
          </mx:HDividedBox>
          <mx:states>
              <mx:State name="videoState">
                  <mx:AddChild relativeTo="{content}">
                      <mx:VideoDisplay id="videoDisplay" width="100%" height="100%" />
                  </mx:AddChild>
              </mx:State>
              <mx:State name="imageState">
                      <mx:Image id="image" width="100%" height="100%" />
                  </mx:AddChild>
              </mx:State>
          </mx:states>
      I really don't know where to start, as I am not using <mx:WIndowApplication> instead I am using <mx:VBox> to currently display media. This was the only way I could get everyone to work how I wanted to.
      If anyone can provide code snippets, it would be greatly appreciated.
      Tim
        • 1. Re: States and XML mix
          rtalton Level 4
          Looks like you are trying to merge two different AIR projects together. Try reading the help docs for custom components to see how to set up a component with the logic you need to do this.
          • 2. Re: States and XML mix
            tjay99 Level 1
            I get the general idea about components, but I am trying to merge only part of the last script with my original. Basically this part:
                                    case "flv":
                                        break;
                                     case "png":
                                    case  "jpg":
                                        viewer =  image;
                                        break;
                                     default:
                                         return;
                 </mx:Script>
                    </mx:VBox>
                 </mx:HDividedBox>
                <mx:states>
                         </mx:AddChild>
                    </mx:State>
                        </mx:AddChild>
                     </mx:State>
                 </mx:states>
            so I can still use the XML loading section.
            Are you able to write something for me by any chance, to at least get me moving in the right direction?
            Tim
