6 Replies Latest reply on Mar 21, 2011 10:50 AM by tooMuchTrouble
    best way to underline data in datagrid?
    tooMuchTrouble Level 3
      i need to underline text in a column based on certain criteria. i've tried a few approaches (itemRenderer using label.htmlText & setting styles) but the performance was pretty bad. can anyone suggest a better approach to this?
      thanks.
        • 1. Re: best way to underline data in datagrid?
          Codeflayer Level 1
          We would probably need some more information to fully help. Typically I just
          create a custom renderer and set the label styles based on parameters coming
          in from the data provider. You might be doing something odd that's causing
          the performance issue. Can you give us an example of the item renderer and
          the data provider?
          • 2. Re: best way to underline data in datagrid?
            for the label.htmlText approach, pretty straight forward:
            <s:MXDataGridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                 xmlns:mx="library://ns.adobe.com/flex/mx"
                  focusEnabled="true"
                 creationComplete="setText();">
            <fx:Script>
            <![CDATA[
            private function setText():void {
                 if (data.msgStatus=="_S")
                      lblData.htmlText="<u>S</u>";
                 else
                      lblData.htmlText=data.msgStatus;
            </fx:Script>
            <mx:Label id="lblData" top="0" left="0" right="0" bottom="0" width="64"/>
            </s:MXDataGridItemRenderer>
            --oops forgot the style approach:
                  focusEnabled="true"
            <fx:Script>
            <![CDATA[
                 if (data.msgStatus=="_S_")
                      lblData.styleName="deliveredMsg";
                 else
                 lblData.styleName="regularMsg";
            </fx:Script>
            <mx:Label id="lblData" top="0" left="0" right="0" bottom="0" width="64" text="{data.Message_Status}"/>
            this prerforms margianlly better but if you filter the datagrid or scroll much, the renderers are sticky & render that row of data, no matter the data.
            should i be using set data approach instead?
            thanks.
            • 3. Re: best way to underline data in datagrid?
              Codeflayer Level 1
              Ah, I see the problem. I've had really poor luck using creation complete
              methods within item renderers. It's due to the fact that the renderers get
              reused and not created again. That would probably be why you see strange
              behavior or performance problems. Try this instead:
              "value"</u>";
                    else
                         return value
              </fx:Script>
              <mx:Label id="lblData" htmlText="{setText(data)}" top="0" left="0"
              • 4. Re: best way to underline data in datagrid?
                Codeflayer Level 1
                I hate it when my code gets munged in the email. Lets try this again:
                        focusEnabled="true"
                <fx:Script>
                <![CDATA[
                       else
                msgStatus;
                </fx:Script>
                • 5. Re: best way to underline data in datagrid?
                  Codeflayer Level 1
                  HAHA! Third times the charm.
                          focusEnabled="true">
                  <fx:Script>
                  <![CDATA[
                  private function setText(value:Object):String {
                         if (value.msgStatus=="_S")
                              return "<u>"+value+"</u>";
                         else
                              return value
                  </fx:Script>
                  <mx:Label id="lblData" htmlText="{setText(data)}" top="0" left="0" right="0" bottom="0" width="64"/>
                  • 6. Re: best way to underline data in datagrid?
                    thanks i'll give it a shot. yeah i see your point about creationComplete (and
                    now that you point it out, pretty obvious).
