3 Replies Latest reply on Mar 21, 2011 10:02 AM by Colin Brougham
    Premiere -> Final Cut -> DVCAM
    SDCone Level 1
      Hi there,
      I have a friend who is helping me make a DVCAM tape of a feature of mine, for an upcoming film festival, as I don't have a deck at home. Anyway, the film was edited in Premiere Pro (edited in CS4 but I've now got it in CS5), shot 720p on the Panasonic HVX200 and the tape will be made from Final Cut. What are my best exporting options for getting it over to him in the proper format and quality?
      Thanks much,
      Stephen
        • 1. Re: Premiere -> Final Cut -> DVCAM
          Colin Brougham Level 6
          If you're delivering in DVCAM, you may as well just export to a QuickTime DV file. Since you mentioned 720p, I'm assuming you shot 720p/24pN, and edited in a matching sequence. Select QuickTime as your Format, select the NTSC DV Widescreen 24p preset, and apply a crop of 8 pixels to the top and bottom of the source to eliminate the black bars. You'll probably want to check the Maximum Render Quality option; it'll take longer but give better results. The resulting MOV will import directly into FCP and output to DVCAM tape without issue.
          • 2. Re: Premiere -> Final Cut -> DVCAM
            SDCone Level 1
            Thanks, Colin. I feel like every time I've tried to export a Quicktime in the past it's come out either squashed or elongated; always misshapen. Is there something I'm doing wrong? I've always been under the general impression that Premiere and Quicktime didn't play nice.
            Stephen
            • 3. Re: Premiere -> Final Cut -> DVCAM
              Well, it depends on whether you're submitting your movie as widescreen anamorphic (squashed/squished/squeezed), widescreen-in-a-letterbox, or as a center crop or extract. Any distortion you saw was probably due to the fact that QuickTime Player (if that's what you were using for playback) doesn't typically read anamorphic flags well.
              Again, I'm assuming that you were working in an HD sequence--that is, widescreen--and you want to preserve that aspect ratio. Since you're going to DV(CAM), that can only be one thing: 720x480, 29.97LFF (I'm of course referring to NTSC Land here, which is where I presume you're residing). If you want to preserve the widescreen ratio, you need to use pixels with a PAR for widescreen; the NTSC DV Widescreen preset will set this up. You'll keep that 720x480 squeezed image (also known as Full Height Anamorphic) right through to the DVCAM tape; it'll then be up to playback deck and projection to properly scale that to a widescreen projection.
              You might want to check with the submission details to make sure they can accept this, but that's how all DV/SD widescreen video is recorded--even DVDs work the same way.
              QuickTime works fine in Premiere, even on a PC; what you probably read was a lot of misinformation based on no actual practice. Since FCP is QuickTime native, anyway (and a lot more limited in formats than Premiere is), your best bet is to feed it what it likes.
