1 Reply Latest reply on Mar 25, 2011 8:54 AM by JohnDevlon
    [AS CS5] How to check if pageitem has associated xml element?
    JohnDevlon Level 1
      HI,
      Can anyone please help me?
      I would like to know if a pageitem has an associated xml element but I can't get it to work in applescript.
                                      set allItems to all page items of myCurrentPage
                                      repeat with aItem in allItems
                                          if not (associated XML element of aItem = null) then
                                              set currentXML to associated XML element of aItem
                                              if name of markup tag of currentXML is "myText" then
                                                   -- do something
                                              end if
                                          end if
                                      end repeat
      How do I check if a pageitem has an associated xml element? The code above doesn't solve the issue...
      Any feedback would be great.
      Kind regards
      John
        • 1. Re: [AS CS5] How to check if pageitem has associated xml element?
          JohnDevlon Level 1
          It took me lot of sleepless nights but i found a solution that works:
                    repeat with c from 1 to number of items in allItems
                              set aItem to item c of allItems
                              set assXMLcheck to "valid"
                              try
                                   set assXMLcheck to (associated XML element of aItem) as string
                                   -- if the associated XML element is empty or not set
                                   -- the string will be set to "«constant ****nada»"
                                   -- In other cases, if the item has an associated xml element,
                                   -- this will raise an error and the string will not change
                              end try
                              if assXMLcheck is "valid" then
                                   set currentXMLTag to markup tag of currentXML
                                   set currentXMLTagName to name of currentXMLTag
                                   display dialog currentXMLTagName
                              end if
                    end repeat
          It will not become part of earth history as most beautiful programming solution ever, but it works
          John
