1 Reply Latest reply on Mar 21, 2011 1:48 PM by gkaiseril
    Formula to divide field entry by a number
    NAESAfelicity
      I have two form fields. One is set as a dollar amount and needs to be calculated by dividing the other form field entry by a specific number. I've tried multiple scripts that I found by searching all over the internet, but nothing works.
      Does somebody know what the script should be, AND where can I go to learn about scripting?
        • 1. Re: Formula to divide field entry by a number
          Did you change the field names to match your field names?
          JavaScript does not generate a number result when dividing by zero. It creates either an 'NaN' string value or a string value for the number 'Infinity' or '-Infinity'. So unless you are placing your result in field with a format of "None", you need to control your code to avoid dividing by zero.
          Since there is a possibility of dividing by zero, and simplified field notation can not handle conditional processing, the 'fi' statement, you need to write a custom calculation script.
          For the field to hold the result of the calculation:
          // establish variables for the field names for the dividend and divisor.
          var sDividend = 'My Dividend Field Name';
          var sDivisor = 'My Divisor Field Name';
          // get the value of the divisor field
          var nDivisor = this.getField(sDivisor).value;
          // get the value of the dividend field
          var nDividend = this.getField('sDividend').vlalue;
          // do not change the code below this line
          // clear the result field value
          event.value = '';
          // see if we have a non-zero divisor
          if (nDivisor != 0) {
             // we can now divide
             event.value = nDividend / nDivisor;
          } // end division calculation
          The above assumes your are dividing the values of 2 fields.
          There are tutorials at the Acrobat Users Community and Planet PDF. Ted Padova has written a number of books about Acrobat and Acrobat Forms.
