3 Replies Latest reply on Mar 22, 2011 3:26 PM by Flex harUI
    Remove DataGrid Header Separator dynamically
    Bhargav_Flex Level 1
      Hello,
      Scenario: I have a DG with 3 static columns and many dynamic columns added at run time.
      I want to have one and only one header for all the dynamic columns.
      In a way it can be seen as multiple datagridColumns (without headers) in  a single dataGridColumn (with only a header). Now there is a heavy traffic between static columns and the dynamic columns. So I dont think it is possible to have two different DG's.
      My Attempts: I tried to use the HeaderSeparatorSkin to remove the header separators so as to give a feel of one single header. But since the headerseparatorskin is removed at DG level it can be either removed for all columns or for none.
      My Question: I will have to create a custom DG so as to draw separator skin for few columns and remove for others. But I am not sure how can I do that since using "headerSeparatorSkin" removes it for all columns. Can some one show me a path as to how I can accomplish this?
      A very bad way of accomplishing the above is to remove all the header separator skins and then use headerRenderer for the static columns to show a line similar to separator skin. But that is a bad way of coding I guess.
      Thanks in advance,
      Bhargav
