3 Replies Latest reply on Mar 22, 2011 7:45 PM by Ned Murphy
    Array / Function Scoping issue
    ChrisH
      Hi All,
      Can someone confirm this please?
      If I declare an array in a function, is that array only available / accessible in the scope of that function?  That is, does it have a local scope to the function only?
      I ask because I am unable to access values in the array outside of the defining function.
      As an example:
      function myFunction () {
           //other code e.g. specifying length of array, etc
      for (i=0; i<myArray.length; i++) {
           myArray[i] = currentValue + i;
           //other code
      trace (myArray); // undefined is showing up here.
      Do I have to do something like this inside the function to make the values available to the root and other functions?
      _root.myArrayGlobal = myArray; // inside the function
      trace (myArrayGlobal); //this then appears to work outside of the function
      I just want to confirm to ensure the only issue I'm having is a scoping one.
      If so is this the “best practice” way to do it?
      Thank you
      Best Regards
      Chris
