1 Reply Latest reply on Mar 22, 2011 8:10 PM by Shongrunden
    Spark List TileLayout rowCount issue
    OrthATG
      I have a simple list control that is populated by an arrayCollection.  The data is valid, and there are always 6 items in the collection.  When using a tileLayout, it only shows 1 row (2 items), or when I set the orientation to columns, it only shows 1 column (3 items).  It behaves this way with or without a custom itemRenderer.  When I debug, I can see that requestedRowCount = 3, my dataProvider has 6 valid items, the height of the list is as it should be if there were 3 rows, but rowCount = 1.
      If I remove the TileLayout, it displays all 6 items vertically (as expected).
      I've used TileLayout before and it has worked just fine.  Any help would be much appreciated.
      List is contained in a view created from PopupManager:
      <s:List dataProvider="{_collection}"
                      top="233"
                      width="300"
                      itemRenderer="com.here.is.my.renderer">
                  <s:layout>
                <!-- I know only one of the requestedCounts is used depending on the orientation, but these are the 2 options that I've tried-->
                     <s:TileLayout requestedColumnCount="2"
                                    requestedRowCount="3"
                                    horizontalGap="0"
                                    verticalGap="0"/>
                  </s:layout>
              </s:List>
      Thanks!
        • 1. Re: Spark List TileLayout rowCount issue
          Shongrunden Adobe Employee
          This example seems to work fine for me:
                         xmlns:s="library://ns.adobe.com/flex/spark">
              <s:List width="300">
                  <s:dataProvider>
                      <s:ArrayList>
                          <fx:String>0</fx:String>
                          <fx:String>1</fx:String>
                          <fx:String>2</fx:String>
                          <fx:String>3</fx:String>
                          <fx:String>4</fx:String>
                          <fx:String>5</fx:String>
                      </s:ArrayList>
                  </s:dataProvider>
                  <s:layout>
                                    horizontalGap="0"
                                    verticalGap="0" />
                  </s:layout>
              </s:List>
          </s:Application>
          Can you please provide a similar example that demonstrates the issue you are seeing?
