1. Re: enquiry
JSS1138 Mar 22, 2011 8:58 PM (in response to Phoenicianvideo)Probably the same way you install any other program - run the executable.
2. Re: enquiry
John T Smith Mar 23, 2011 8:29 AM (in response to Phoenicianvideo)>have a prodad Ned to install it in adobe Pro CS5
Is that hardware or software?
Does the vendor say it is designed to be installed in Premiere Pro CS5?
Does the vendor provide instructions on HOW to install in Premiere Pro CS5?
3. Re: enquiry
joe bloe premiere Mar 23, 2011 9:11 AM (in response to Phoenicianvideo)It does not appear to be compatible with CS5... only CS4 and earlier:
4. for enquiry
Phoenicianvideo Jun 19, 2011 9:52 PM (in response to JSS1138)Dear sir,
I'm Planing to build a desktop Pc for video editing with adobe Pro cs5.
And this is the Specs i'm trying to buy,
Motherboard Asus Premium P6X58D,
CPU i7-960 3,20Ghz, DDR3 2000
10Gb Ram memory
Graphic Card GTX 650Ti, 1GB,
are those Parts that am buying will Make the Video editing Faster and will work together with the best result with adobe Pro Cs5.
Thank you so Much for your Help
John
5. Re: for enquiry
Harm Millaard Jun 19, 2011 11:25 PM (in response to Phoenicianvideo)John,
10 GB is not possible on that platform. 12 GB (3 x 4 GB) would be the minimum.
The video card must be a typo. You meant the GTX 560 Ti, right?
You will need many more parts, like a case, fans, CPU cooler, PSU and most important, hard disks.
6. for enquiry
Phoenicianvideo Jun 26, 2011 3:32 AM (in response to joe bloe premiere)Dear sir
I am having a Problem with running the Project in the adobe pro CS5,
and the followings Specs for My computer is:
Motherboard Asus P8Z68 V-Pro
intel Core i7-2600k, 3,40Ghz
8 GB Ram memory
Graphic card GTX 560 Ti, 1GB
Power supplies 750watts
Every times i try to open a project it takes 3 to 6 mins to start and when i try to use my feature on the system the computer freezes,.
for 2 to 10 mins again, and then starts working for a while until it freezes also.
So from looking to my Desktop Specs can you Please help me to find the Problem? which causing that to Happen.
Thank you so Much
John
7. Re: for enquiry
Harm Millaard Jun 26, 2011 4:06 AM (in response to Phoenicianvideo)John,
You are unclear as to who you are asking for a reply.
But the symptoms you describe are very likely caused by an ill-tuned, underspecced system. Hard to say without details, that are severely lacking.
Look here: Some suggestions... and answer at least the 16 questions at the end of the Wiki article.
8. Re: for enquiry
Bill Gehrke Jun 26, 2011 7:33 AM (in response to Phoenicianvideo)If this is your current system:
Phoenicianvideo wrote:
Dear sir
8 GB Ram memory
Thank you so Much
John
You must have a serious problem because that is a pretty good configuration. In addition to Harm's request for more detail please try running our PPBM5 (Premiere Pro Benchmark) and send in the results so we might be able to help identify any problem area. One possible problem might be something is overheating causing those timeouts. Do you have a CPU temperature monitoring program to see what is happening to it?
