4 Replies Latest reply on Mar 23, 2011 4:14 AM by EvyatarBH
    Wordwrap in DataGrid
    Ameya Mogare
      I want to implement DataGrid control that should: -
      1. wordwrap the text inside the cell (no horizontal scrollbars) (note skill5 in Array)
      2. put a vertical scrollbar when no. of entries exceed 5
      3. hide column headers
      I have following initial code: -
          <mx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  [Bindable]
                  public var MySkills : ArrayCollection = new ArrayCollection( [
                        {label:"skill1", MySkill:"SAP", Prof:"Expert"},
                        {label:"skill2", MySkill:"JAVA", Prof:"Expert"},
                        {label:"skill3", MySkill:".NET", Prof:"BEGINER"},
                        {label:"skill4", MySkill:"ORACLE", Prof:"BEGINER"},
                        {label:"skill5", MySkill:"WEB SERVICES4 ABCDEFGH", Prof:"EXPERT"},
                        {label:"skill6", MySkill:"Adobe Flex", Prof:"BEGINER"}
          </mx:Script>
            <mx:DataGrid id="myGrid" dataProvider="{MySkills}">
                   <mx:columns>
                       <mx:DataGridColumn  dataField="MySkill"/>
                       <mx:DataGridColumn dataField="Prof" />
                   </mx:columns>
             </mx:DataGrid>
      Please guide/help.
      Thanks and regards,
      Amey
        • 1. Re: Wordwrap in DataGrid
          senthil s
            Try this code
          place this code in datagrid header:
          1.rowcount"{MySkills.length}"
          if u want to set 5 statically means use rowcount="5"  otherwise dont use rowcount nd on verticalscrollpolicy="true";
          2.showHeader"true"
          3.verticalscrollpolicy="true"
                       <mx:columns>
                       </mx:columns>
                 </mx:DataGrid>
          • 2. Re: Wordwrap in DataGrid
            senthil s Level 1
            if u want to hide datagrid header use showHeader="false".
            Thanks&Regards,
            senthil
            • 3. Re: Wordwrap in DataGrid
              senthil s Level 1
                Use Item renderer concept:
                           <mx:columns>
                               <mx:DataGridColumn  dataField="MySkill">
              <mx:itemRenderer>
              <fx:Component>
              <mx:HBox horizontalScrollPolicy="off">
              <fx:Script>
              <![CDATA[
              override public function set data(value:Object):void
              super.data=value;
              Txt_Area.text=
              data.MySkill;
              </fx:Script>
              <mx:TextArea id=Txt_Area  wordwrap="true"  width="10"/>
              </mx:HBox>
              </fx:Component>
              </mx:itemRenderer>
              </mx:DataGridColumn>
                           </mx:columns>
                     </mx:DataGrid>
              • 4. Re: Wordwrap in DataGrid
                EvyatarBH Level 3
                Although this is marked as Answered, I think there's a much simpler and better solution by setting the following DataGrid properties -
                variableRowHeight="true"
                wordWrap="true"
                Good luck!
