Hi all,
currently Robohelp includes hyperlinks into the ePub output but when the user clicks them they produce errors (at least with Adobes own ePub reader ADE). Because the output files are contained in an archive it may not be possible to link to other topics at all but then why does RoboHelp include internal hyperlinks at all if they do not work?
It seems awkward to tag all paragraphs which contain hyperlinks with conditional build tags and then remove them from output just to avoid errors. Is there a more elegant solution?
I would try another reader first to establish where the problem is. Try the Firefox Add On ePub Reader. Post back with the results.
After checking, I have to correct myself. Evidently it is rather a problem with language-specific characters (ä, ß) in file names. These topics cannot be viewed using the TOC either. If I insert a standard hyperlink to a topic that has no such character in its file name, then all is well. The problem is that these file names are generated automatically by Robohelp when a Word document is imported.
I might issue a request about this in the feature request form.
@Praful Jain:
1. RH9, older versions dont support ePub I think.
2. Correctly, these are topic within the project.
3. In case you are still interested please tell, but I think its a different problem now altogather as described above.
RH8 did, but you had to run a script that the RH dev team provided on their blog.
The RH8 script provided on the blog doesn't work. I've modified the RH9 script to also work with RH8. See http://www.wvanweelden.eu/robohelp/scripts/ebook
Greet,
Willam
Hi Robert,
Can you please elaborate on the following things.
you can email me @ praful@adobe.com
Praful Jain
Adobe RoboHelp Team
