0 Replies Latest reply on Mar 23, 2011 5:06 AM by Theresa54321
    Flash Catalyst Fails to Launch
    Theresa54321
      I installed Flash, Flash Builder and Flash Catalyst and while the first two run normally, Flash catalyst starts up with the splash screen but then shuts down on its own. After searching several forums and errors, I came across this error in c:\documents and settings\administrator\application data\adobe\flash catalyst\workspace\.metadata\.log
      !ENTRY org.eclipse.osgi 4 0 2011-03-23 07:58:38.515
      !MESSAGE
      !STACK 0
      java.io.IOException: The system cannot find the path specified
      at java.io.WinNTFileSystem.createFileExclusively(Native Method)
      at java.io.File.checkAndCreate(Unknown Source)
      at java.io.File.createTempFile(Unknown Source)
      at org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveStateData(BaseStorage.java:590)
      at org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveAllData(BaseStorage.java:429)
      at org.eclipse.osgi.internal.baseadaptor.BaseStorage.frameworkStop(BaseStorage.java:828)
      at org.eclipse.osgi.baseadaptor.BaseAdaptor.frameworkStop(BaseAdaptor.java:272)
      at org.eclipse.osgi.framework.internal.core.SystemBundleActivator.stop(SystemBundleActivator .java:66)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl$3.run(BundleContextImpl.java:1 050)
      at java.security.AccessController.doPrivileged(Native Method)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:10 46)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.suspendAllBundles(StartLevelMa nager.java:685)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java :637)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelMana ger.java:312)
      at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.jav a:257)
      at org.eclipse.osgi.framework.internal.core.SystemBundle.suspend(SystemBundle.java:236)
      at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:678)
      at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:576)
      at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.java:41)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:420)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:200)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
      If anyone has any ideas what could be causing this error, any help would be greatly appreciated.
