2 Replies Latest reply on Mar 25, 2011 1:09 AM by paon.m
    pointSize problem
    paon.m Level 1
      I have a problem to set a float value as point size of a line,character,word,etc.. :
      line.pointSize=7.6; //NOT WORK
        line.pointSize=7; // WORK!
      I have to set a line point size to 7,6 pt. What I have to do?
      I'm working with Indesign Server CS4 and CS5.
      Thanks in advance
      Massimo
        • 1. Re: pointSize problem
          Harbs. Level 6
          What happens if you try this?
          line.pointSize = "7.6";
          Harbs
          • 2. Re: pointSize problem
            paon.m Level 1
            I found the problem, but i don't understand why..
            This is my code that work :
            var lines=clone.lines;
            for (var z=0; z < lines.length-1; z++) {
                  lines[z].contents=' \r';
            var last_line=clone.lines.lastItem();
            last_line.pointSize = "7.6";
            This is the old code that don't work:
            Probably when I set the content of the previous line to ' \r' also the content of the last line is influenced. But with integer values of pointSize also the old code work.., it's weird.
