2 Replies Latest reply on Mar 23, 2011 12:51 PM by muubs
    How to hide PDF/A info panel and show signature info panel? (plugin)
    muubs Level 1
      Hello,
      When opening a document that is PDF/A compliant and also has a digital signature then PDF/A info panel is always displayed with the text:
      The file you have opened complies with the PDF/A standard and has been opened read-only to prevent modification.
      Instead I would like my plugin to display the usual signature info panel:
      Signed and all signatures are valid.
      It's possible to get that behaviour by setting Preferences -> Documents -> PDF/A -> PDF/A View Mode to "Never".
      What I would like to do instead is to programmatically set the info bar to display signature status (for documents that are being verified by my plugin, probably inside dsGetValidState). For all other documents opening them in PDF/A mode by default is fine.
      Any ideas how to do it with the SDK from inside the plugin?
