3 Replies Latest reply on Mar 24, 2011 8:22 AM by Jim_Babbage
    CS5 library HTML instances not getting updated (and font options are limited)
    jeffboston
      Having the following problems using FW CS5/Mac:
      1. Heading1 instances (created from Common Library -> HTML) are not reflecting updates to library item in Document Library.
      To replicate: Drag a Heading1 element from the common library to document.  Create a few more instances of it in the document, using the one in your Document Library.  Now edit the library version. The instances on the page stay the same, they don't reflect updates.
      2. Symbol Properties for HTML elements has very limited options for Font.   'Heading1' has only Arial or Arial Black.  'Link' has those, plus Comic Sans (and Arial is listed twice).  There is nowhere else to customize symbols.
      3. Also, my Layers panel randomly disappears, even though Window->Layers is still checked. I have to restart to get it back.  Cursor also sometimes disappears and requires restart. Seems to happen whenever I add a Link (from Common Library).
      Are there workarounds for these?  If they are documented bugs, is there a patch?
      Thanks for any help.
      Jeff
        • 1. Re: CS5 library HTML instances not getting updated (and font options are limited)
          Jim_Babbage Level 4
          The Heading symbols are Rich Symbols.As such most of their properties are controlled in the symbol properties panel at the instance level, not within the symbol itself.
          Some attributes that CAN be changed at the symbol level are font style (bold, underline etc) tracking (letter spacing), anti-aliasing and Live Filters.
          There are indeed far more font choices in the symbol properties than you have mentioned - they're just not all visible. Click the font list and then use the incredibly tiny scroll bar on the right to move through the font list.
          I can't replicate the Layers panel issue.
          HTH
          • 2. Re: CS5 library HTML instances not getting updated (and font options are limited)
            jeffboston Level 1
            Thanks Jim.
            In this case, I want my symbol instances to be Lucida Grande.
            In the Symbol Instance, if i select 'Lucida Sans Unicode - Lucida Grande - sans serif' (the only option that has Lucida) the symbol still appears as Arial. Is there a way to customize the list of font options that appear in the dropdown?
            Also, is there a way to change the default settings for the symbol itself instead of having to enter them on every instance?  It seems to defeat the purpose if you have to manually enter all the settings every time you create one.
            • 3. Re: CS5 library HTML instances not getting updated (and font options are limited)
              Jim_Babbage Level 4
              You can try editing the JSF file for the symbol - that's what controls the symbol properties. I'm not a coder, but I found that putting your preferred font at the beginning of the font list in the JSF list will solve the problem.
              For example, I first saved a copy of the original script, then moved the Times Roman family to the beginning of the list and saved this version as the original script name. These scripts are found in the Fireworks application folder, inside Configuration > Common Library > HTML.
              I restarted FW and when I dragged the H1 instance onto the canvas, it displayed Times immeditately.
              Unfortunately, it deleted that family from the combo list, simply renaming it Arial - Helvetica - san-serif and placing it at the top of the list. So now I have 3 Arials - lol. The first one indicates the current font chosen (or it's supposed to) and the other two list my true Arial font family and the Times font family (renamed as Arial)  Haven't figure out how to fix that yet.
              This change doesn't affect the preview image either, but there must be a way to alter it by editing the true symbol.
              HTH a little, at least.
