2 Replies Latest reply on Oct 16, 2012 8:47 AM by dudeness44
    Adobe Flash Player 10 ActiveX -- Error 2753. The File 'InstallAX.exe' is not marked for installation
    OasisLF
      Adobe Flash GPO Deploy error “InstallAx.exe” Flash won’t uninstall
      correctly from a GPO deployment
      Error message from EventViewer: Product: Adobe Flash Player 10
      ActiveX -- Error 2753.The File 'InstallAX.exe' is not marked for
      installation.
      I am running Windows 7 and I am trying to uninstall Adobe Flash
      Player 10 ActiveX yet I can't find it on the list of Add/Remove
      Programs. I have cleaned the registry with CCLEANER application. I
      also followed instructions for removing the registry keys of the
      following website
      http://faultbucket.ca/2010/12/adobe-flash-gpo-deploy-error-installax-exe and still nothing.
      I am stuck and I don't know how to remove Adobe Flash Player 10
      ActiveX from my computer. Can anyone help me Much Appreciated!
        • 1. Re: Adobe Flash Player 10 ActiveX -- Error 2753. The File 'InstallAX.exe' is not marked for installation
          MrTTM
          We had this same problem recently and the faultbucket link pointed me in the right direction however the registry entries were different for us.
          Most of our computers were fine but some had problems with Flash Plugins and some with Activex and some both.
          The  best way to fix a computer or set of computers is to first uninstall  all Flash and then note all remaining Flash entries in  HKEY_CLASSES_ROOT\Installer\Products.
          These entries can vary based on what versions got corrupted on your systems.
          This  ended up being the fix for us for both Flash Plugin and ActiveX  version. We tested it and had great success as a .reg file and are now  deploying it via GPO.
          (We had 4 defunct registry entries for Flash plugin and 3 for Activex)
          Windows Registry Editor Version 5.00
          [-HKEY_CLASSES_ROOT\Installer\Products\371245C90F69D5349AC564C8AA7CE50A]
          [-HKEY_CLASSES_ROOT\Installer\Products\6205276E056AC94498B76D7B5AEE0A85]
          [-HKEY_CLASSES_ROOT\Installer\Products\6F8CE5C1F5C5F12458EB19B9D5C0DAC4]
          [-HKEY_CLASSES_ROOT\Installer\Products\FB0D7F53BA803E244A30FA7927CA12A6]
          [-HKEY_CLASSES_ROOT\Installer\Products\30D9D84132D5F4D45B0DAB06034CD5FC]
          [-HKEY_CLASSES_ROOT\Installer\Products\C460100B160DEAB4091314A638D85563]
          [-HKEY_CLASSES_ROOT\Installer\Products\4E867BFF724E3554CB631AF1E5269AD4]
          (if you copy and paste this fix remove the spaces near the end of the line added by these forums for some reason)
          Reply if this solution or a similar one works for you.
          • 2. Re: Adobe Flash Player 10 ActiveX -- Error 2753. The File 'InstallAX.exe' is not marked for installation
            dudeness44 Level 1
            What would you recommend in an enviroment of over 100 computers, some in different office, where a small percentage of automated flash deployments are failing? The above fixes dont help. Thanks
