0 Replies Latest reply on Mar 23, 2011 3:33 PM by hitenjava123
    IndexOutOfBoundsException error on compile
    hitenjava123
      Came across an error which took me hours to locate the cause.
      Something like the code below compiles fine:
      public function function1():void{
                      obj.addEventListener(MyEvent.
                          MY_EVENT_TYPE,
                          function onEvent(event:Event):void {
                                    function2(classname);
      public function function2(className:String):void{
                      var objClass:Class =
                              getDefinitionByName(classNameStr) as Class;
                          if (objClass != null) {
                              myContent = (UIComponent(new objClass()));
      But if I put the code in the same function instead, it throws up an error on compiling (without even specifying the class which has the error.)
      The code:
                          MY_EVENT_TYPE,
                          var objClass:Class = getDefinitionByName(classNameStr) as Class;
      The error:
      compile-application:
           [exec] Loading configuration file C:\...\flex\frameworks\fl
      ex-config.xml
           [exec] Error: Index: 16, Size: 16
           [exec]
           [exec] java.lang.IndexOutOfBoundsException: Index: 16, Size: 16
           [exec]     at java.util.ArrayList.RangeCheck(Unknown Source)
           [exec]     at java.util.ArrayList.get(Unknown Source)
           [exec]     at macromedia.asc.semantics.ReferenceValue.getSlot(ReferenceValu
      e.java:253)
           [exec]     at macromedia.asc.embedding.LintEvaluator.evaluateGenericCallExp
      ression(LintEvaluator.java:202)
           [exec]     at macromedia.asc.embedding.LintEvaluator.evaluate(LintEvaluator
      .java:379)
           [exec]     at macromedia.asc.parser.CallExpressionNode.evaluate(CallExpress
      ionNode.java:46)
      .java:1025)
           [exec]     at macromedia.asc.parser.MemberExpressionNode.evaluate(MemberExp
      ressionNode.java:57)
      .java:1268)
           [exec]     at macromedia.asc.parser.ArgumentListNode.evaluate(ArgumentListN
      ode.java:45)
      ression(LintEvaluator.java:269)
      .java:454)
      ionNode.java:46)
      .java:1025)
      .java:1324)
           [exec]     at macromedia.asc.parser.ListNode.evaluate(ListNode.java:44)
      .java:1310)
      ode.java:45)
      .java:875)
           [exec]     at macromedia.asc.parser.SetExpressionNode.evaluate(SetExpressio
      nNode.java:58)
      .java:1025)
      .java:1324)
      .java:1398)
           [exec]     at macromedia.asc.parser.ExpressionStatementNode.evaluate(Expres
      sionStatementNode.java:50)
      .java:1346)
           [exec]     at macromedia.asc.parser.StatementListNode.evaluate(StatementLis
      tNode.java:60)
      .java:1438)
           [exec]     at macromedia.asc.parser.IfStatementNode.evaluate(IfStatementNod
      e.java:50)
      .java:1346)
      tNode.java:60)
      .java:1867)
           [exec]     at macromedia.asc.parser.FunctionCommonNode.evaluate(FunctionCom
      monNode.java:104)
      .java:1848)
      monNode.java:104)
      .java:2321)
           [exec]     at macromedia.asc.parser.ClassDefinitionNode.evaluate(ClassDefin
      itionNode.java:106)
      .java:2042)
           [exec]     at macromedia.asc.parser.ProgramNode.evaluate(ProgramNode.java:8
      0)
           [exec]     at flex2.compiler.as3.Compiler.analyze4(Compiler.java:611)
           [exec]     at flex2.compiler.API.analyze(API.java:2542)
           [exec]     at flex2.compiler.API.analyze(API.java:2432)
           [exec]     at flex2.compiler.API.batch2(API.java:411)
           [exec]     at flex2.compiler.API.batch(API.java:1117)
           [exec]     at flex2.compiler.API.compile(API.java:1290)
           [exec]     at flex2.compiler.API.compile(API.java:1210)
           [exec]     at flex2.tools.Compiler.mxmlc(Compiler.java:275)
           [exec]     at flex2.tools.Compiler.main(Compiler.java:53)
      BUILD FAILED
