7 Replies Latest reply on Jun 21, 2007 12:43 PM by Newsgroup_User
    Problem loading a movie
    Level 7
      I have a movie Products.swf which uses ASP to display some data from an MYSL
      database. This works on the server okay as a SWF or within an HTML.
      I have a main Movie Products_main that has a blank movie call Blank_Movie.
      I have a text box converted to a button with actioscript as follows:
      on (release) {
      _root.Blank_Movie.loadMovie("products.swf");
      When I click on the button the movie loads but all I see is a blue box
      (movie background) but none of data or fields.
      If I drag the products movie into the Products_main movie the products movie
      simply flashes and does not show any data.
      ie this works http://80.5.54.164/cactus/cactushop5_1/products.html
      But when called from
      http://80.5.54.164/cactus/cactushop5_1/products_main.html (click on all
      tickets)
      It fails.
      Any help appreciated
      Cheers
      SteveW
        • 1. Re: Problem loading a movie
          on the main timeline of products.fla, you can add
          this._lockroot=true;
          to try for a quick-fix. if that fails, you will need to post the code in products.swf used to call your asp script.
          • 2. Re: Problem loading a movie
            Level 7
            I use :
            loadVariablesNum(" http://80.5.54.164/cactus/cactushop5_1/employee5.asp", 0);
            Cheers
            SteveW
            "kglad" <webforumsuser@macromedia.com> wrote in message
            news:f4eass$5mb$1@forums.macromedia.com...
            • 3. Re: Problem loading a movie
              SymTsb Level 2
              My guess is that the issue is with code in the products.fla file and how it creates the textfields on the screen. Are you using _root at all to create them? If so, it would better explain why the data isn't showing up.
              • 4. Re: Problem loading a movie
                so what? did enabling _lockroot resolve the problem?
                • 5. Re: Problem loading a movie
                  Level 7
                  Sorry forgot to mention enabling_lockroot did not solve the problem
                  news:f4ijso$46a$1@forums.macromedia.com...
                  • 6. Re: Problem loading a movie
                    then you'll need to post the code that's loading and displaying the data in products.fla.
                    • 7. Re: Problem loading a movie
                      Level 7
                      Code as follows:
                      first frame:
                      second frame:
                      if (_root.Counter == 1) {
                      gotoAndStop(3);
                      } else {
                      gotoAndPlay(1);
                      Third frame:
                      // depth
                      depth = -1;
                      // hide the origional clips
                      Name._visible = 0;
                      Age._visible = 0;
                      Date1._visible = 0;
                      Status._visible = 0;
                      // split up the array by looking for the commas
                      Name_array = output.split(",");
                      Age_array = eoutput.split(",");
                      Date1_array = edate1.split(",");
                      Status_array = estatus.split(",")
                      // get the length of the array
                      Name_length = Name_array.length;
                      Age_length = Age_array.length;
                      Date1_length = Date1_array.length;
                      Status_length = Status_array.length;
                      // set the start y position (x position depends on where you put it on the
                      screen)
                      yposition = 38;
                      // looping everything
                      for (i=0; i<Name_length; i++) {
                      // Name
                      duplicateMovieClip(Name, "Name" add i, depth);
                      setProperty("Name" add i, _y, yposition);
                      Name.Name = Name_array[1];
                      set("Name" add i add ".info", Name_array );
                      // need to set the link here on click event
                      depth--;
                      // Age
                      duplicateMovieClip(Age, "Age" add i, depth);
                      setProperty("Age" add i, _y, yposition);
                      Age.Age = Age_array[1];
                      set("Age" add i add ".info", Age_array
                      depth--;
                      // Set the y position plus 30
                      //yposition = yposition+10;
                      duplicateMovieClip(Date1, "Date1" add i, depth);
                      setProperty("Date1" add i, _y, yposition);
                      Date1.Date1 = Date1_array[1];
                      set("Date1" add i add ".info", Date1_array );
                      depth--;
                      duplicateMovieClip(Status, "Status" add i, depth);
                      setProperty("Status" add i, _y, yposition);
                      set("Status" add i add ".info", Status_array
                      depth--;
                      yposition = yposition+15;
