5 Replies Latest reply on Mar 24, 2011 10:44 PM by Flex harUI
    DataGridColumn editable false?
    snkd Level 1
      how to dinamically make editable false for datagridColumn ?
      my code is like that
      <mx:DataGridColumn
      dataField="dispatch"
      headerText="Dispatch"
      resizable="false"
      sortable="false"
      editorDataField="selected"
      rendererIsEditor="true"
      itemRenderer="mx.controls.CheckBox"
      </mx:DataGridColumn>
      when I always try to set editable false for column.but it never became as I need.Any Ideas?
        • 1. Re: DataGridColumn editable false?
          snkd Level 1
          here is the sample
          <!--Project :UserLevel~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~-->
          <!--File     :TestGrid.mxml~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~-->
          <!--Date    :Mar 24, 2011~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~-->
          <!--Author     :Administrator~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~-->
          xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          [Bindable]
          private var acDao:ArrayCollection=new ArrayCollection();
          protected function button1_clickHandler(event:MouseEvent):void
          acDao.addItem({col1:1,col2:2,col3:true});
          acDao.addItem({col1:11,col2:22,col3:false});
          acDao.addItem({col1:12,col2:23,col3:true});
          acDao.addItem({col1:13,col2:24,col3:false});
          protected function button2_clickHandler(event:MouseEvent):void
          for each(var temp:Object in dgDao.dataProvider as ArrayCollection)
          trace("first :"+temp["col1"]+"second :"+temp["col2"]+"third :"+temp["col3"]);
          </fx:Script>
          <fx:Declarations>
          <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <!--Visual Components Here~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~-->
          <mx:DataGrid x="300" y="194" id="dgDao" dataProvider="{acDao}" editable="true">
          <mx:columns>
          <mx:DataGridColumn headerText="Column 1" dataField="col1"/>
          <mx:DataGridColumn headerText="Column 2" dataField="col2"/>
          <mx:DataGridColumn headerText="CheckBox" dataField="col3" editable="true" itemRenderer="mx.controls.CheckBox" editorDataField="selected" rendererIsEditor="true"/>
          </mx:columns>
          </mx:DataGrid>
          <s:Button x="300" y="150" label="Load" click="button1_clickHandler(event)"/>
          <s:Button x="383" y="150" label="view" click="button2_clickHandler(event)"/>
          </s:Application>
          How can I make the checkbox column editable false dinamically?
          • 2. Re: DataGridColumn editable false?
            EvyatarBH Level 3
            What if you change the rendererIsEditor property to false and add editable="false"?
            Another option would be to make the checkbox's click event handler call event.preventDefault()
            • 3. Re: DataGridColumn editable false?
              Flex harUI Adobe Employee
              What code are you using to set it to false?
              • 4. Re: DataGridColumn editable false?
                snkd Level 1
                yes alex,I am using Id for DataGridColumn and try to set editable false for paticular column.
                • 5. Re: DataGridColumn editable false?
                  That's not code, that's a description.  Post a 20-line test case showing the
                  problem.
