8 Replies Latest reply on Mar 30, 2011 2:45 AM by Kents79
    Pausing a movieclip
    Kents79 Level 1
      Hi
      I tried to get this right but it just won't work for me. It's probably something very simple.
      I have a video in a movieclip on my timeline. On the first frame, I have the stop(); command. I want to be able to hit the SPACEBAR: which results in pausing the movieclip and jumping to frame 2 on the timeline.
      Can anybody help me with this please.
        • 1. Re: Pausing a movieclip
          Is the video spread along the timeline of the movieclip--if you put a stop() part way thru the movieclip's timeline does it stop?  Do you know how to code for keyboard interactions?
          • 2. Re: Pausing a movieclip
            Kents79 Level 1
            Hi Ned
            Thanks for your reply.
            Yes the video is spread along the timeline in the movieclip so if I place a stop command on the timeline......the video would stop.
            Is there a way to have a moiveclip on your time line. When it's playing, if you hit the Spacebar.......it pauses the movieclip......brings up a pause icon symbol.....then after 3 seconds jumps to another scene. Is this possible?
            E
            • 3. Re: Pausing a movieclip
              You should try inserting the stop  I suggested to see that it does indeed stop to your satisfaction (you might find otherwise).
              Yes, you can do what you want, but it will involve creating a pause icon that you display and using a time delay code to delay moving to another scene.
              The general approach to the code would be...
              pause_icon._visible = false;
              var keyListener:Object = new Object();
              Key.addListener(keyListener);
              keyListener.onKeyUp = function(){
                  if(Key.getCode() == 32){  // SPACE key
                        yourVideoMCName.stop();  // substitute your movieclip name
                        pause_icon._visible = true;
                        var sto = setTimeout(moveAlong, 3000);
              function moveAlong(){
                   gotoAndStop(wherever);
              • 4. Re: Pausing a movieclip
                Kents79 Level 1
                Hey Ned
                That worked perfectly. Thank you very much for all of your help.
                Emmet
                • 5. Re: Pausing a movieclip
                  Kents79 Level 1
                  Hi Ned
                  Sorry to bother you again...............quick question for you.
                  I have a menu.exe file that I use to launch 3 separate .exe files (housed in a " Fscommand" folder)
                  When I publish for Windows/Mac projector................the windows version works great.
                  But when I test it on the Mac......the call to action doesn't work.
                  The following is what I have:
                  on (keyPress "") {
                       fscommand("Exec", "screen_01.exe");
                  Regards
                  Emmet
                  • 6. Re: Pausing a movieclip
                    You are always better off starting new postings for new questions, especially if they have no relationship to your original question.
                    I have no clue what might be failing with a Mac... not my cup of tea.
                    • 7. Re: Pausing a movieclip
                      Kents79 Level 1
                      Ok, cheers.
                      • 8. Re: Pausing a movieclip
                        Kents79 Level 1
                        Hi Ned
                        Sorry to bother you again. I like to thank you for your help.
                        I have a question in relation to your mail.
                        I have my 'menu.swf' loading an external 'video.swf'.
                        I have your script on the first frame of ‘video.swf’
                                  video_ad.stop();  // substitute your movieclip name
                                                          loadMovie("assets/pause.swf", 95);
                             gotoAndStop("home_promotions");
                                        unloadMovie(90);
                        How do I get the playback head to jump to a certain framlabel on the 'menu.swf' when I press 'SPACEBAR' to run the above script on the ‘video.swf’
                        Also, the pause icon appears straight away when the ‘video.swf’ starts?
                        Regards
                        Emmet
