3 Replies Latest reply on Mar 24, 2011 4:13 AM by areohbee
    updateFromEarlierSchemaVersion
    areohbee Level 6
      How to debug?
      Its not working, and the error goes by so fast I have no idea what the problem is.
      i.e. If I click 'Enable', then 'OK' when prompted to update catalog, an error message comes up for split second, then the plugin is disabled again - no diagnostic messages are indicated...
      This is the (...updateFromEarlierSchemaVersion) function:
      local function updateFunc( _cat, previousSchemaVersion, scope )
          local id = "com.robcole.dev.PixelCountMetadata"
          if previousSchemaVersion == 1 then
              local photos = _cat:findPhotosWithProperty( id, 'PixelCount' ) -- ###1 , 1 )
              -- local photos = _cat:getAllPhotos()
              for i, photo in ipairs( photos ) do
                  local pc = photo:getPropertyForPlugin( id, 'PixelCount' ) -- ###1 , 1 )
                  photo:setPropertyForPlugin( _PLUGIN, 'PixelCount', tostring( pc ) )
                  if scope then
                      scope:setPortionComplete( i, #photos )
                  end
              end
          end
      end
      I dont recall I've ever been able to get a schema update function to work - always just worked around it...
      Rob
        • 1. Re: updateFromEarlierSchemaVersion
          areohbee Level 6
          Found the answer from myself, via a previous post, he-he...
          http://forums.adobe.com/message/3358149
          Still, I've found no way to debug or tell anything about what is going on when its failing - any insight anyone?
          If this is just how it is, then this MUST be improved in next SDK release.
          Rob
          • 2. Re: updateFromEarlierSchemaVersion
            areohbee Level 6
            OK - I was going for an update to plugin #2, and I am now completely unable to re-release it.
            All I did was add a couple metadata items, which I didnt think constituted a need to update the schema. In any case, I've tried and tried, but have not been able to enable the plugin, update the catalog, nor figure any reason why.
            H E L P ! ! !
            H E L P ! ! !
            H E L P ! ! !
            Rob
            • 3. Re: updateFromEarlierSchemaVersion
              areohbee Level 6
              Got it!
              This time I had to bump the version numbers on what were brand new metadata items - although catalog had never been successfully updated with any version number before.
              Last plugin I fixed it by NOT bumping the version number on pre-existing item that had changed data-types.
              I cant figure this out - this is really ripe for a fix, or an explanation... (yes I've reported it).
              Rob
