4 Replies Latest reply on Mar 24, 2011 12:54 PM by csb102155
    Scripting for eliminating zeros
    csb102155 Level 1
      Hi, I have an adobe acrobat form (Acrobat Professional 8.0) and I've added the javascript to calculate a column of fields.  I used this code:
      var f = this.getField("MSFund");
      var a = f.getArray();
      var sum = 0;
      for (i = 0; i < a.length; i ++)
      sum += a[i].value;
      event.value = sum;
      When I try to put in a code to hide zeros in this same field, I get a synpax error message.  Does anyone know the proper code for hiding zeros and where would I add it in this script mentioned above?
      Thanks for any assistance you can give on this.
      Connie
        • 1. Re: Scripting for eliminating zeros
          Add this at the end:
          if (event.value===0) event.value = "";
          • 2. Re: Scripting for eliminating zeros
            csb102155 Level 1
            Thanks for your quick response.  However, now, not only does the form not calculate, but it doesn't hide the zeros either.  Is the code appropriate?  What I want is to total a column of fields and hide the zeros.
            This is the script;
            var sum = 0;
            sum += a[i].value;
            event.value = sum;
            var sum = 0;
            Thanks much for your help.
            Connie Bretes
            • 3. Re: Scripting for eliminating zeros
              What error code and what coding statements?
              var sum = 0;
              sum += a[i].value;
              event.value =  sum == 0? "" : sum; // use null string for zero result
              Or:
              var sum = 0;
              sum += a[i].value;
              if (sum == 0)
                 event.value = ""; null zero result
              else
                 event.value = sum; // display result
              You might want to open the JS debugging console and see if you have any errors. Acrobat JS stops working as soon as any error is encountered.
              • 4. Re: Scripting for eliminating zeros
                csb102155 Level 1
                Thank you for your assistance.  I finally got it to work!
                Connie
