Hi Everyone,
Like in Word, file can be saved by clicking on 'save as' and that makes a copy of the existing file. I was wondering if something like that can be done in RH6 HTML, I want to create a new project using the existing project. Basically, creating a new version of the project while keeping the old version intact. Is it possible? I would appreciate if anybody can guide me on that.
Sangeeta
Hi Sangeeta
RoboHelp does not offer any form of File > Save As. But this does not mean you cannot accomplish what you want.
Basically what you need to do is close the project in RoboHelp. Then from Windows Explorer, copy the folder to a new location. Then open the project in the new location and click File > Rename Project. Once you do this you will have a completely new project you can then begin to modify.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
Thanks Rick for your quick respons.
I have been trying to reply you since yesterday but somehow there was no link to reply you in your response box. Well, anyway i am finally in luck to be able to reply you back.
I tried your suggestion but the Rename option is disabled for me, perhaps, my RH 6 project is connected to Microsoft Visual Source Safe (VSS) version control software. In the mean time this is what i have tried and still stuck with the problem:
Any help would be much appreciated.
Thanks again.
Hello again
See if the article below helps any.
Cheers... Rick
Thanks for the prompt reply again.
I went through the article but it is disassociating version control software from the RH project. I want to change the association from old location to new location.
While RH project is still associated to VSS (version control software), is the xpj file the only file to be changed? And, is changing the VSS folder path to the new location (<value>"$/Version3.2/Web/RoboHelp", MQVEAAAA</value>) from its old location (<value>"$/Version2.4/Web/RoboHelp", MQVEAAAA</value>) is the only change needs to be done in xpj file.
Regards,
Sangeeta
