1 Reply Latest reply on Mar 29, 2011 12:38 AM by Lutz@Evonik
    Problem with FTE in DataTips of PlotChart (missing texts)
    Lutz@Evonik Level 1
      Hi @all,
      we have decided to use the Flex 4.1 and Flash text engine in our projects.
      Now I have the following problem with the dataTips: the texts are appearing only partly if datatips of more than one point are showing. The behavior is not regularly.
      Here is my code for testing (compiler options: hook at "Use Flash Text engine in MX components":
        xmlns:mx="library://ns.adobe.com/flex/mx"
        minWidth="955"
        minHeight="600"
        creationComplete="init()">
        <fx:Declarations>
          <mx:SolidColor id="sc1" color="#EC6605" alpha=".3"/>
          <mx:SolidColorStroke id="s1" color="#EC6605" weight="1"/>
        </fx:Declarations>
        <fx:Script>
          <![CDATA[
            import mx.charts.HitData;
            import mx.collections.ArrayCollection;
            [Bindable]
            private var seriesAverageScores:ArrayCollection = new ArrayCollection(new Array());
            private static const tipDataString:String = "zeile 1 zeile 1 zeile 1\nzeile 2 zeile 2 zeile 2\nzeile 3 zeile 3 zeile 3\nzeile 4 zeile 4 zeile 4\n -\n -\n -";
            private function init():void {
              seriesAverageScores.addItem({x: 1, y: 2, dataTip: tipDataString});
              seriesAverageScores.addItem({x: 2, y: 2, dataTip: tipDataString});
              seriesAverageScores.addItem({x: 3, y: 2, dataTip: tipDataString});
              seriesAverageScores.addItem({x: 1.1, y: 2, dataTip: tipDataString});
              seriesAverageScores.addItem({x: 1.05, y: 2, dataTip: tipDataString});
              seriesAverageScores.addItem({x: 0.95, y: 2, dataTip: tipDataString});
              seriesAverageScores.addItem({x: 1.2, y: 2, dataTip: tipDataString});
              seriesAverageScores.addItem({x: 1.15, y: 2, dataTip: tipDataString});
              seriesAverageScores.addItem({x: 1.12, y: 2, dataTip: tipDataString});
            private function dataTipFunction_average(hd:HitData):String {
              var val:String;
              var d:Object = hd.item as Object;
              return d.dataTip;
        </fx:Script>
        <s:VGroup width="100%"
          height="100%">
          <mx:PlotChart id="myChart1" width="100%" height="100%"
            dataTipFunction="dataTipFunction_average" showDataTips="true">
            <mx:verticalAxis>
              <mx:LinearAxis title="TurnOvers" padding="0.1" minimum="0" maximum="50"/>
            </mx:verticalAxis>
            <mx:horizontalAxis>
            <mx:LinearAxis title="Scores" padding="0.1" minimum="0" maximum="10"/>
            </mx:horizontalAxis>
            <mx:series>
              <mx:PlotSeries dataProvider="{seriesAverageScores}"
                name="series 1" fill="{sc1}" stroke="{s1}"
                displayName="Average Scores per customer"
                xField="x"
                yField="y">
              </mx:PlotSeries>
            </mx:series>
          </mx:PlotChart>
        </s:VGroup>
      </s:Application>
      Has anyone an idea how to solve this ?
      Thanks, Lutz
