6 Replies Latest reply on Mar 26, 2011 2:11 PM by reteb
    1.Harm's Guideline for Disk Usage 2. Hardware RAID controller yes or no ?
    reteb
      1.
      Assuming that Harm's Guidelines in the row " 4 disks recommendations " should read  as " D " or " E and F " ( and not " D or E " and "F " ) I wonder which choice to make with 2 x 300 GB Raptors 10K in RAID 0 : should I config the RAID in D or in E+F ?
      What difference(s) does the choices make compared to each other ?
      2.
      Am I right in assuming that only 2 x R0 does not need a non mobo hardware controller, even no " real one '"  e.g. Areca ?
      3.
      What is, on the average,  the expected RAID 0 I/O speed loss ( in one array for 2x R0 or for 4x R0 ) caused by the mobo controller and Intel software compared to the theoretical 200 % ?
      4.
      After how many RAID 0 disks in one array a hardware controller ( the real ones and the cheap $ 100-150 ones ) starts to show a significant speed advantage over the mobo /software RAID 0 controller ?
      Thanks for explanation.
        • 1. Re: 1.Harm's Guideline for Disk Usage 2. Hardware RAID controller yes or no ?
          Harm Millaard Level 7
          1.
          It is meant to be read as: "D and F" or "E and F".
          2.
          Correct.
          3.
          Almost n x 100%. With n = 2, you would end up with 190 - 200%, with n = 4, you would end up with 380 - 400%.
          4.
          Raid0 hardly uses any resources. The benefit of a hardware raid controller shows with parity raids, and parity raids show their benefit in added security.
          • 2. Re: 1.Harm's Guideline for Disk Usage 2. Hardware RAID controller yes or no ?
            reteb Level 1
            Harm,
            Thanks, very clear.
            One more thing : what difference(s) does (do) D+F make compared to and E+F ?
            Doesn't the D+F be preferred since the projects files are then in the R0 array ?
            When should I opt for D+F and when for E+F ?
            • 3. Re: 1.Harm's Guideline for Disk Usage 2. Hardware RAID controller yes or no ?
              There is no single rule for this. It depends on your projects. Take two extremes:
              1. Long form documentary, lots of long clips, few transitions or effects and I would choose D and F.
              2. Short music clips, numerous multicam situations, many tracks, lots of effects and I would choose E and F.
              It depends on the nature of your project and what it entails for the disk usage. So no clear answer, unfortunately.
              I hope you can understand my reassoning and can benefit from it.
              • 4. Re: 1.Harm's Guideline for Disk Usage 2. Hardware RAID controller yes or no ?
                reteb Level 1
                Yes, this very helpful, thanks.
                I opt for D+F. with 10k Raptors.
                My mobo permits one more separate R0 array, should I prefer C or E ?
                • 5. Re: 1.Harm's Guideline for Disk Usage 2. Hardware RAID controller yes or no ?
                  It is not advised to raid the boot disk, so the answer is E, but the question is with what other drive?
                  • 6. Re: 1.Harm's Guideline for Disk Usage 2. Hardware RAID controller yes or no ?
                    reteb Level 1
                    I have 12 SATA ports : 6 SATAII for Intel(R)ICH10R RAID 0 ( I will only use RAID 0 ) for D+F.
                    And 6 more SATA3 ports, 2 of them could be configured for Marvell 9128 RAID 0 for E ( and the remaining 4 ports as non RAID Marvell 9120 , 1 of them as eSATA ).
                    As trials I used  the SATAII RAID 0 and the SATA3 Marvell RAID 0 separately of each other, each satisfactorily ( backups as Acronis images, separately to be stored in my safe,  out of and into the frontside backplane SATA HDD's bays.)
                    I am told they could be used together and this weekend I give it a try.
