2 Replies Latest reply on Nov 9, 2011 11:01 AM by John Blackburne
    Flash CS5 Crash when editing preferences
    tdelam2
      Does it happen to anyone else when you edit anything in the preferences window that Flash CS5 crashes? I've reinstalled the program as well.. any tips I can try?
        • 1. Re: Flash CS5 Crash when editing preferences
          *Q Level 3
          Hi tdelam2,
          Does it crash for you everytime? Which platform are you working on (Mac or Window)? Would you happen to have reproducible steps or the crash log available?
          Please let me know.
          Quynh
          Flash Authoring, QA
          • 2. Re: Flash CS5 Crash when editing preferences
            John Blackburne Level 1
            This happens to me too, every time. Version 11.5.1.349 on a Mac, OSX 10.6.8. Change any setting and hit save. Crash log:
            Process:         Adobe Flash CS5.5 [1035]
            Path:            /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/Adobe Flash CS5.5
            Identifier:      com.adobe.flash
            Version:         11.5.1.349 (11.5.0)
            Code Type:       X86 (Native)
            Parent Process:  launchd [142]
            Date/Time:       2011-11-08 15:06:56.338 +0000
            OS Version:      Mac OS X 10.6.8 (10K549)
            Report Version:  6
            Exception Type:  EXC_BAD_ACCESS (SIGBUS)
            Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000000002dc
            Crashed Thread:  0  Dispatch queue: com.apple.main-thread
            Application Specific Information:
            Java information:
            Exception type: Bus Error (0xa) at pc=0000000000cffb4c
            Java VM: Java HotSpot(TM) Client VM (20.1-b02-384 mixed mode macosx-x86)
            Current thread (0000000055002000):  JavaThread "main" [_thread_in_native, id=-1606216384, stack(00000000bf800000,00000000c0000000)]
            Stack: [00000000bf800000,00000000c0000000]
            Java Threads: ( => current thread )
              000000006409a400 JavaThread "Thread-4" [_thread_blocked, id=-1311825920, stack(00000000b1bf2000,00000000b1cf2000)]
              0000000055125c00 JavaThread "FelixPackageAdmin" daemon [_thread_blocked, id=-1316052992, stack(00000000b17ea000,00000000b18ea000)]
              0000000055124400 JavaThread "FelixStartLevel" daemon [_thread_blocked, id=-1318264832, stack(00000000b15ce000,00000000b16ce000)]
              0000000055123800 JavaThread "FelixDispatchQueue" [_thread_blocked, id=-1319321600, stack(00000000b14cc000,00000000b15cc000)]
              0000000064004400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1321435136, stack(00000000b12c8000,00000000b13c8000)]
              0000000064003400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=-1322491904, stack(00000000b11c6000,00000000b12c6000)]
              00000000550b9400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1323548672, stack(00000000b10c4000,00000000b11c4000)]
              00000000550b8400 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=-1324605440, stack(00000000b0fc2000,00000000b10c2000)]
              00000000550ad400 JavaThread "Finalizer" daemon [_thread_blocked, id=-1329291264, stack(00000000b0b4a000,00000000b0c4a000)]
              00000000550ac400 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1330348032, stack(00000000b0a48000,00000000b0b48000)]
            =>0000000055002000 JavaThread "main" [_thread_in_native, id=-1606216384, stack(00000000bf800000,00000000c0000000)]
            Other Threads:
              00000000550a9800 VMThread [stack: 00000000b07bf000,00000000b08bf000] [id=-1333006336]
              0000000064005c00 WatcherThread [stack: 00000000b13ca000,00000000b14ca000] [id=-1320378368]
            VM state:not at safepoint (normal execution)
            VM Mutex/Monitor currently owned by a thread: None
            Heap
            par new generation   total 14784K, used 6658K [0000000057810000, 0000000058810000, 0000000058810000)
              eden space 13184K,  50% used [0000000057810000, 0000000057e90890, 00000000584f0000)
              from space 1600K,   0% used [0000000058680000, 0000000058680000, 0000000058810000)
              to   space 1600K,   0% used [00000000584f0000, 00000000584f0000, 0000000058680000)
            concurrent mark-sweep generation total 110184K, used 24845K [0000000058810000, 000000005f3aa000, 000000005f810000)
            concurrent-mark-sweep perm gen total 30676K, used 18404K [000000005f810000, 0000000061605000, 0000000063810000)
            Code Cache  [0000000055801000, 0000000055f22000, 0000000057801000)
            total_blobs=3035 nmethods=2884 adapters=92 free_code_cache=26107392 largest_free_block=384
            Virtual Machine Arguments:
            JVM Args: -Djava.awt.headless=true -Xmx128m
            Java Command: <unknown>
            Launcher Type: generic
            Physical Memory: Page Size = 4k, Total = 3072M, Free = 232M
            Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
            0   com.adobe.flash                         0x00cffb4c std::vector<CPicASObj*, std::allocator<CPicASObj*> >::push_back(CPicASObj* const&) + 24986
            1   com.adobe.flash                         0x008db3a9 CMoviePrefixHandler::~CMoviePrefixHandler() + 45559
            2   com.adobe.flash                         0x008e8a57 CMoviePrefixHandler::~CMoviePrefixHandler() + 100517
            3   com.adobe.flash                         0x00fee3f7 CMiniFrameWnd::~CMiniFrameWnd() + 825
            4   com.adobe.flash                         0x00fcb817 non-virtual thunk to CButtonOwnerDrawImpl::~CButtonOwnerDrawImpl() + 9613
            5   com.adobe.flash                         0x0103252c non-virtual thunk to CStdioFile::~CStdioFile() + 19790
            6   com.adobe.flash                         0x010317db non-virtual thunk to CStdioFile::~CStdioFile() + 16381
            7   com.adobe.flash                         0x0102e587 non-virtual thunk to CStdioFile::~CStdioFile() + 3497
            8   com.adobe.flash                         0x00252a4e KeyNameToMenuGlyphMap::KeyNameToMenuGlyphMap() + 10112
            9   com.adobe.flash                         0x011cb08d CList<MMUI::DocumentFrame*, MMUI::DocumentFrame*>::~CList() + 4429
            10  com.adobe.flash                         0x010317db non-virtual thunk to CStdioFile::~CStdioFile() + 16381
            11  com.adobe.flash                         0x0035fa4b non-virtual thunk to CFlashDocTemplate::ActivateAccelerators(TAcceleratorVector) + 3557
            12  com.adobe.flash                         0x0102e587 non-virtual thunk to CStdioFile::~CStdioFile() + 3497
            13  com.adobe.flash                         0x00252a4e KeyNameToMenuGlyphMap::KeyNameToMenuGlyphMap() + 10112
            14  com.adobe.flash                         0x0101c3b1 non-virtual thunk to CScrollViewImpl::ListenToMessage(long, void*) + 4687
            15  com.adobe.flash                         0x010b84e6 non-virtual thunk to LCarbonApp::MakeSelfSpecifier(AEDesc&, AEDesc&) const + 698
            16  com.apple.HIToolbox                     0x91f6bc2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
            17  com.apple.HIToolbox                     0x91f6aef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
            18  com.apple.HIToolbox                     0x91fd82a1 CallNextEventHandler + 95
            19  com.adobe.flash                         0x011c232f CTypedPtrArray<CPtrArray, MMUI::PanelPlaceholder*>::~CTypedPtrArray() + 2401
            20  com.adobe.dvaui.framework               0x0931412c dvaui::ui::OS_Window::CallCarbonEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 108
            21  com.adobe.dvaui.framework               0x0931cbe1 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*), boost::_bi::list3<boost::_bi::value<OpaqueEventHandlerCallRef*>, boost::_bi::value<OpaqueEventRef*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 33
            22  com.adobe.dvacore.framework             0x096b7949 boost::function0<int>::operator()() const + 41
            23  com.adobe.dvacore.framework             0x096b6c01 dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::functio n0<int>) + 17
            24  com.adobe.dvaui.framework               0x093139a4 dvaui::ui::OS_Window::CarbonEventHandlerProc(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 164
            25  com.apple.HIToolbox                     0x91f6bc2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
            26  com.apple.HIToolbox                     0x91f6aef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
            27  com.apple.HIToolbox                     0x91f8d7f3 SendEventToEventTarget + 52
            28  com.apple.HIToolbox                     0x91fb9e87 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
            29  com.apple.HIToolbox                     0x91fdeb90 SendMenuCommandWithContextAndModifiers + 66
            30  com.apple.HIToolbox                     0x91fdeb47 SendMenuItemSelectedEvent + 121
            31  com.apple.HIToolbox                     0x91fdea5d FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
            32  com.apple.HIToolbox                     0x91fae160 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
            33  com.apple.HIToolbox                     0x92160936 MenuSelect + 190
            34  com.apple.HIToolbox                     0x921198e0 HIMenuBar::HandleMouseEvent(OpaqueEventRef*) + 92
            35  com.apple.HIToolbox                     0x91f6c22b HIObject::EventHook(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 173
            36  com.apple.HIToolbox                     0x91f6bc2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
            37  com.apple.HIToolbox                     0x91f6aef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
            38  com.apple.HIToolbox                     0x91f8d7f3 SendEventToEventTarget + 52
            39  com.apple.HIToolbox                     0x91f9f3ef ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1417
            40  com.apple.HIToolbox                     0x91f6c080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
            41  com.apple.HIToolbox                     0x91f6aef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
            42  com.apple.HIToolbox                     0x91f8d7f3 SendEventToEventTarget + 52
            43  com.apple.HIToolbox                     0x92116c17 ToolboxEventDispatcher + 86
            44  com.apple.HIToolbox                     0x92116d4f RunApplicationEventLoop + 243
            45  com.adobe.flash                         0x010244aa non-virtual thunk to CFileDialogImpl::~CFileDialogImpl() + 4302
            46  com.adobe.flash                         0x00ffcead CTimerImpl::~CTimerImpl() + 279
            47  com.adobe.flash                         0x00ffcf59 CTimerImpl::~CTimerImpl() + 451
            48  com.adobe.flash                         0x00265182 devtech_private::Buffer<unsigned short>::Grow(unsigned long) + 1506
            Thread 1:  Dispatch queue: com.apple.libdispatch-manager
            0   libSystem.B.dylib                       0x93147382 kevent + 10
            1   libSystem.B.dylib                       0x93147a9c _dispatch_mgr_invoke + 215
            2   libSystem.B.dylib                       0x93146f59 _dispatch_queue_invoke + 163
            3   libSystem.B.dylib                       0x93146cfe _dispatch_worker_thread2 + 240
            4   libSystem.B.dylib                       0x93146781 _pthread_wqthread + 390
            5   libSystem.B.dylib                       0x931465c6 start_wqthread + 30
            Thread 2:
            0   libSystem.B.dylib                       0x93120b42 semaphore_wait_signal_trap + 10
            1   libSystem.B.dylib                       0x9314e6f8 _pthread_cond_wait + 1089
            2   libSystem.B.dylib                       0x9319705f pthread_cond_wait + 48
            3   com.adobe.amt.services                  0x0be9d274 C_AMTUISwitchSuppressUpdates + 16864
            4   com.adobe.amt.services                  0x0be96074 C_EULA_SetState + 2166
            5   com.adobe.amt.services                  0x0be9d2da C_AMTUISwitchSuppressUpdates + 16966
            6   libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            7   libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 3:
            0   libSystem.B.dylib                       0x9314eaa2 __semwait_signal + 10
            1   libSystem.B.dylib                       0x9314e75e _pthread_cond_wait + 1191
            2   libSystem.B.dylib                       0x931503f8 pthread_cond_wait$UNIX2003 + 73
            3   ...ple.CoreServices.CarbonCore          0x980de21e TSWaitOnCondition + 126
            4   ...ple.CoreServices.CarbonCore          0x980c9b68 TSWaitOnConditionTimedRelative + 202
            5   ...ple.CoreServices.CarbonCore          0x980c5533 MPWaitOnQueue + 250
            6   com.adobe.ACE                           0x060c5309 0x608a000 + 242441
            7   com.adobe.ACE                           0x060c4d01 0x608a000 + 240897
            8   ...ple.CoreServices.CarbonCore          0x980a954a PrivateMPEntryPoint + 68
            9   libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            10  libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 4:
            0   libSystem.B.dylib                       0x9315e0d6 recvfrom$UNIX2003 + 10
            1   libSystem.B.dylib                       0x9317deab recv$UNIX2003 + 54
            2   ServiceManager-Launcher.dylib           0x2405a2d7 Invoke + 54887
            3   ServiceManager-Launcher.dylib           0x24059376 Invoke + 50950
            4   ServiceManager-Launcher.dylib           0x24058227 Invoke + 46519
            5   ServiceManager-Launcher.dylib           0x24058279 Invoke + 46601
            6   ServiceManager-Launcher.dylib           0x24058303 Invoke + 46739
            7   ServiceManager-Launcher.dylib           0x24052706 Invoke + 23190
            8   ServiceManager-Launcher.dylib           0x240528ef Invoke + 23679
            9   ServiceManager-Launcher.dylib           0x240534cf Invoke + 26719
            10  ServiceManager-Launcher.dylib           0x240535cd Invoke + 26973
            11  ServiceManager-Launcher.dylib           0x240569b8 Invoke + 40264
            12  ServiceManager-Launcher.dylib           0x24056c61 Invoke + 40945
            13  ServiceManager-Launcher.dylib           0x2405728f Invoke + 42527
            14  ServiceManager-Launcher.dylib           0x2405748c Invoke + 43036
            15  ServiceManager-Launcher.dylib           0x2404911a Login + 1654
            16  ServiceManager-Launcher.dylib           0x2404a6f7 Login + 7251
            17  ServiceManager-Launcher.dylib           0x240579fb Invoke + 44427
            18  ServiceManager-Launcher.dylib           0x24059f49 Invoke + 53977
            19  libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            20  libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 5:  Java: Exception Handler Thread
            0   libSystem.B.dylib                       0x93120afa mach_msg_trap + 10
            1   libSystem.B.dylib                       0x93121267 mach_msg + 68
            2   libSystem.B.dylib                       0x9318cc78 mach_msg_server + 520
            3   libjvm.dylib                            0x2d3db0eb jio_snprintf + 43803
            4   libjvm.dylib                            0x2d3daf80 jio_snprintf + 43440
            5   libjvm.dylib                            0x2d3d9d2d jio_snprintf + 38749
            Thread 6:  Java: Gang worker#0 (Parallel GC Threads)
            2   libjvm.dylib                            0x2d64d4c9 JVM_RaiseSignal + 365377
            3   libjvm.dylib                            0x2d3da0e6 jio_snprintf + 39702
            4   libjvm.dylib                            0x2d641681 JVM_RaiseSignal + 316665
            5   libjvm.dylib                            0x2d641750 JVM_RaiseSignal + 316872
            6   libjvm.dylib                            0x2d3d9c5d jio_snprintf + 38541
            7   libjvm.dylib                            0x2d3eecbe jio_vsnprintf + 333
            8   libjvm.dylib                            0x2d3d9d2d jio_snprintf + 38749
            Thread 7:  Java: Gang worker#1 (Parallel GC Threads)
            Thread 8:  Java: Concurrent Mark-Sweep GC Thread
            2   libjvm.dylib                            0x2d64d599 JVM_RaiseSignal + 365585
            3   libjvm.dylib                            0x2d64d93c JVM_RaiseSignal + 366516
            4   libjvm.dylib                            0x2d64169b JVM_RaiseSignal + 316691
            7   libjvm.dylib                            0x2d4890c9 JVM_Close + 13205
            8   libjvm.dylib                            0x2d489031 JVM_Close + 13053
            9   libjvm.dylib                            0x2d3f4d73 jio_vsnprintf + 25090
            10  libjvm.dylib                            0x2d3d9d2d jio_snprintf + 38749
            11  libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            12  libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 9:  Java: VM Thread
            7   libjvm.dylib                            0x2d45b564 JVM_Lseek + 149378
            8   libjvm.dylib                            0x2d45b214 JVM_Lseek + 148530
            9   libjvm.dylib                            0x2d3d9d2d jio_snprintf + 38749
            10  libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            11  libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 10:  Java: Reference Handler
            4   libjvm.dylib                            0x2d64982c JVM_RaiseSignal + 349860
            5   libjvm.dylib                            0x2d688b5f JVM_RaiseSignal + 608727
            6   libjvm.dylib                            0x2d46850a JVM_MonitorWait + 196
            7   libjvmlinkage.dylib                     0x22e5de75 JVM_MonitorWait + 69
            8   ???                                     0x5580b9d9 0 + 1434499545
            9   ???                                     0x55803e31 0 + 1434467889
            10  ???                                     0x55803e31 0 + 1434467889
            11  ???                                     0x55801374 0 + 1434456948
            12  libjvm.dylib                            0x2d45c7aa JVM_Lseek + 154056
            13  libjvm.dylib                            0x2d45c544 JVM_Lseek + 153442
            14  libjvm.dylib                            0x2d468341 JVM_StartThread + 2726
            15  libjvm.dylib                            0x2d468246 JVM_StartThread + 2475
            16  libjvm.dylib                            0x2d4681d4 JVM_StartThread + 2361
            17  libjvm.dylib                            0x2d468048 JVM_StartThread + 1965
            18  libjvm.dylib                            0x2d467ea7 JVM_StartThread + 1548
            19  libjvm.dylib                            0x2d3d9d2d jio_snprintf + 38749
            20  libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            21  libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 11:  Java: Finalizer
            9   ???                                     0x55a43380 0 + 1436824448
            10  ???                                     0x55801374 0 + 1434456948
            11  libjvm.dylib                            0x2d45c7aa JVM_Lseek + 154056
            12  libjvm.dylib                            0x2d45c544 JVM_Lseek + 153442
            13  libjvm.dylib                            0x2d468341 JVM_StartThread + 2726
            14  libjvm.dylib                            0x2d468246 JVM_StartThread + 2475
            15  libjvm.dylib                            0x2d4681d4 JVM_StartThread + 2361
            16  libjvm.dylib                            0x2d468048 JVM_StartThread + 1965
            17  libjvm.dylib                            0x2d467ea7 JVM_StartThread + 1548
            18  libjvm.dylib                            0x2d3d9d2d jio_snprintf + 38749
            Thread 12:  Java: Surrogate Locker Thread (Concurrent GC)
            6   libjvm.dylib                            0x2d3d9ba4 jio_snprintf + 38356
            7   libjvm.dylib                            0x2d4789d7 JVM_IsPrimitiveClass + 5991
            8   libjvm.dylib                            0x2d468048 JVM_StartThread + 1965
            9   libjvm.dylib                            0x2d467ea7 JVM_StartThread + 1548
            Thread 13:  Java: Signal Dispatcher
            0   libSystem.B.dylib                       0x93120b36 semaphore_wait_trap + 10
            1   libjvm.dylib                            0x2d479209 JVM_IsPrimitiveClass + 8089
            2   libjvm.dylib                            0x2d478bf4 JVM_IsPrimitiveClass + 6532
            3   libjvm.dylib                            0x2d468048 JVM_StartThread + 1965
            4   libjvm.dylib                            0x2d467ea7 JVM_StartThread + 1548
            Thread 14:  Java: C1 CompilerThread0
            7   libjvm.dylib                            0x2d47fd30 JVM_Write + 288
            8   libjvm.dylib                            0x2d47a368 JVM_IsPrimitiveClass + 12536
            9   libjvm.dylib                            0x2d468048 JVM_StartThread + 1965
            10  libjvm.dylib                            0x2d467ea7 JVM_StartThread + 1548
            11  libjvm.dylib                            0x2d3d9d2d jio_snprintf + 38749
            12  libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            13  libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 15:  Java: Low Memory Detector
            7   libjvm.dylib                            0x2d47bcf6 JVM_IsPrimitiveClass + 19078
            Thread 16:  Java: VM Periodic Task Thread
            3   libjvm.dylib                            0x2d64db2b JVM_RaiseSignal + 367011
            4   libjvm.dylib                            0x2d47ddec JVM_IsPrimitiveClass + 27516
            Thread 17:  Java: FelixDispatchQueue
            11  ???                                     0x55803e31 0 + 1434467889
            12  ???                                     0x55803e31 0 + 1434467889
            13  ???                                     0x5580430d 0 + 1434469133
            14  ???                                     0x55801374 0 + 1434456948
            15  libjvm.dylib                            0x2d45c7aa JVM_Lseek + 154056
            16  libjvm.dylib                            0x2d45c544 JVM_Lseek + 153442
            17  libjvm.dylib                            0x2d468341 JVM_StartThread + 2726
            18  libjvm.dylib                            0x2d468246 JVM_StartThread + 2475
            19  libjvm.dylib                            0x2d4681d4 JVM_StartThread + 2361
            20  libjvm.dylib                            0x2d468048 JVM_StartThread + 1965
            21  libjvm.dylib                            0x2d467ea7 JVM_StartThread + 1548
            22  libjvm.dylib                            0x2d3d9d2d jio_snprintf + 38749
            23  libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            24  libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 18:  Java: FelixStartLevel
            11  ???                                     0x5580430d 0 + 1434469133
            12  ???                                     0x55801374 0 + 1434456948
            13  libjvm.dylib                            0x2d45c7aa JVM_Lseek + 154056
            14  libjvm.dylib                            0x2d45c544 JVM_Lseek + 153442
            15  libjvm.dylib                            0x2d468341 JVM_StartThread + 2726
            16  libjvm.dylib                            0x2d468246 JVM_StartThread + 2475
            17  libjvm.dylib                            0x2d4681d4 JVM_StartThread + 2361
            18  libjvm.dylib                            0x2d468048 JVM_StartThread + 1965
            19  libjvm.dylib                            0x2d467ea7 JVM_StartThread + 1548
            20  libjvm.dylib                            0x2d3d9d2d jio_snprintf + 38749
            21  libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            22  libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 19:  Java: FelixPackageAdmin
            Thread 20:
            1   libSystem.B.dylib                       0x9317a9c5 nanosleep$UNIX2003 + 188
            2   com.adobe.flash.flbridge                0x2531a85b ScObjects::Thread::sleep(unsigned int) + 59
            3   com.adobe.flash.flbridge                0x25314de3 ScObjects::BridgeTalkThread::run() + 163
            4   com.adobe.flash.flbridge                0x2531a968 ScObjects::Thread::go(void*) + 168
            5   libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            6   libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 21:
            3   ...ia.Flash Player.authplaylib          0x21fdf11f 0x21b8f000 + 4522271
            4   ...ia.Flash Player.authplaylib          0x21ba925f 0x21b8f000 + 107103
            5   ...ia.Flash Player.authplaylib          0x21fdf20c 0x21b8f000 + 4522508
            6   ...ia.Flash Player.authplaylib          0x21fdf250 0x21b8f000 + 4522576
            7   ...ia.Flash Player.authplaylib          0x21fdf376 0x21b8f000 + 4522870
            8   libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            9   libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 22:
            Thread 23:  com.apple.CFSocket.private
            0   libSystem.B.dylib                       0x9313fac6 select$DARWIN_EXTSN + 10
            1   com.apple.CoreFoundation                0x94877c53 __CFSocketManager + 1091
            Thread 24:
            0   libSystem.B.dylib                       0x93120b5a semaphore_timedwait_signal_trap + 10
            1   libSystem.B.dylib                       0x9314e6e1 _pthread_cond_wait + 1066
            2   libSystem.B.dylib                       0x9317d5a8 pthread_cond_timedwait_relative_np + 47
            3   ...ia.Flash Player.authplaylib          0x21fdf0e7 0x21b8f000 + 4522215
            4   ...ia.Flash Player.authplaylib          0x21d6f9de 0x21b8f000 + 1968606
            Thread 25:  Java: Thread-4
            3   libjvm.dylib                            0x2d64da6b JVM_RaiseSignal + 366819
            4   libjvm.dylib                            0x2d4b3315 JVM_Sleep + 246
            5   libjvmlinkage.dylib                     0x22e5ea68 JVM_Sleep + 72
            6   ???                                     0x5580b9d9 0 + 1434499545
            7   ???                                     0x55803e31 0 + 1434467889
            8   ???                                     0x5580430d 0 + 1434469133
            9   ???                                     0x55801374 0 + 1434456948
            10  libjvm.dylib                            0x2d45c7aa JVM_Lseek + 154056
            11  libjvm.dylib                            0x2d45c544 JVM_Lseek + 153442
            12  libjvm.dylib                            0x2d468341 JVM_StartThread + 2726
            13  libjvm.dylib                            0x2d468246 JVM_StartThread + 2475
            14  libjvm.dylib                            0x2d4681d4 JVM_StartThread + 2361
            15  libjvm.dylib                            0x2d468048 JVM_StartThread + 1965
            16  libjvm.dylib                            0x2d467ea7 JVM_StartThread + 1548
            17  libjvm.dylib                            0x2d3d9d2d jio_snprintf + 38749
            18  libSystem.B.dylib                       0x9314e259 _pthread_start + 345
            19  libSystem.B.dylib                       0x9314e0de thread_start + 34
            Thread 26:
            2   com.adobe.flash                         0x00f9cf1b dvaui::controls::UI_PictureButton* dvaadameve::UI_Eve::GetTypedControl<dvaui::controls::UI_PictureButton>(boost::intrusive_p tr<dvaui::ui::UI_Node>) + 103083
            3   com.adobe.flash                         0x00f981b3 dvaui::controls::UI_PictureButton* dvaadameve::UI_Eve::GetTypedControl<dvaui::controls::UI_PictureButton>(boost::intrusive_p tr<dvaui::ui::UI_Node>) + 83267
            4   com.adobe.flash                         0x00f9d028 dvaui::controls::UI_PictureButton* dvaadameve::UI_Eve::GetTypedControl<dvaui::controls::UI_PictureButton>(boost::intrusive_p tr<dvaui::ui::UI_Node>) + 103352
            Thread 0 crashed with X86 Thread State (32-bit):
              eax: 0x00000000  ebx: 0x01555c38  ecx: 0x00000001  edx: 0x00000000
              edi: 0xbfffdda8  esi: 0x01555c22  ebp: 0xbfffb078  esp: 0xbfffb060
               ss: 0x0000001f  efl: 0x00010286  eip: 0x00cffb4c   cs: 0x00000017
               ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
              cr2: 0x000002dc
            Binary Images:
                0x1000 -  0x1a55feb +com.adobe.flash 11.5.1.349 (11.5.0) <DE07E6C7-786A-A7C8-1CF2-AE74F688B657> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/Adobe Flash CS5.5
            0x2db8000 -  0x2f32fe3 +com.adobe.PlugPlug 2.5.0.232 (2.5.0.232) <04C90B5C-DC6D-A2B5-BE9B-193466222BE7> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
            0x2fdb000 -  0x30a8fe7 +com.adobe.AXEDOMCore AdobeAXEDOMCore 3.5.101.12783 (3.5.101.12783) <117ACA20-072D-0AB2-CCB9-0385FF43CB14> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
            0x311a000 -  0x31abff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
            0x31ca000 -  0x3297ff3 +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) <08F15219-7F35-574E-7725-1ACAA1B18A00> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.d ylib.36.0
            0x32fa000 -  0x33d4fef +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) <5EE72009-40B3-7FB7-3A49-576AEDE0D400> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
            0x3414000 -  0x3dc4fff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
            0x3dc7000 -  0x3dd2ff3 +libChar16.dylib ??? (???) <758855AC-2E45-350B-D64E-39422835F760> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/libChar16.dylib
            0x3ddb000 -  0x3df4fe7 +libCoreTypes.dylib ??? (???) <4943E74A-FB75-ABB7-C34A-967920772CB4> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/MacOS/libCoreTypes.dylib
            0x3e16000 -  0x3e25fef +ZLib.dylib ??? (???) /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/frameworks/ZLib.dylib
            0x3e2a000 -  0x4034fe7  com.apple.carbonframeworktemplate 1.0 (1.0) <FB292B4C-FDAC-2E77-7540-CE36B139C5E1> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/frameworks/Xerces.framework/Versions/A/Xerces
            0x4372000 -  0x4376ff7  com.apple.JavaVM 13.5.0 (13.5.0) <20F901A0-ED96-1757-E741-28A79EE4CEB2> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
            0x437e000 -  0x5109fe7 +com.adobe.illustrator 382 (15.0.0) <64F68532-0311-6BBA-1F50-246CAF917549> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
            0x5eee000 -  0x5f32fff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <69EDC44E-D7BB-A259-282D-C42725AE0E26> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
            0x5f95000 -  0x5fdbfff +FilterPort ??? (???) <23FAE9D1-9376-1E71-21F7-D3EB2BFD50EE> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
            0x6050000 -  0x6050fff +SPBasic ??? (???) <5D1760D8-C910-C641-0BC9-CF74A1A5190D> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
            0x6054000 -  0x6070ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
            0x608a000 -  0x61c5ff2 +com.adobe.ACE AdobeACE 2.18.00.12659 (2.18.00.12659) <5BD496D2-2E2B-0411-779F-855603C5B2AE> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
            0x61ed000 -  0x66effef +com.adobe.AGM AdobeAGM 4.20.70.12659 (4.20.70.12659) <7F6464ED-C80E-0267-A225-93B2BE537147> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
            0x6834000 -  0x686ffff +com.adobe.ARE AdobeARE 1.5.02.12659 (1.5.02.12659) <639DF4B8-4D45-0517-4DED-D1CB1FC6EC12> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
            0x6879000 -  0x6893fff +com.adobe.BIB AdobeBIB 1.2.02.12659 (1.2.02.12659) <6A0E1ACF-23E8-B966-3B51-8F264E269469> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
            0x689d000 -  0x68beff7 +com.adobe.BIBUtils AdobeBIBUtils 1.1.01 (1.1.01) <F9DA3036-401B-89A5-9512-B009D29A9B2F> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
            0x68cb000 -  0x6bbdff7 +com.adobe.CoolType AdobeCoolType 5.07.124.12659 (5.07.124.12659) <0481471E-E075-0782-BA1C-C5A5E23C5565> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
            0x6c4a000 -  0x7023ff7 +com.adobe.MPS AdobeMPS 5.5.0.12659 (5.5.0.12659) <F15ACFDA-4804-A70B-CA40-13888F4B8A04> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
            0x715a000 -  0x723dfef +com.adobe.PDFPort AdobePDFPort 2.1.0.12659 (2.1.0.12659) <EAF6E16F-E356-551A-0484-50141914178C> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
            0x7275000 -  0x78aafeb +com.adobe.PDFL 9.9.0 (9.9.0.12659) <0C6CF147-E5A9-7C3F-A25C-CD096C910D4D> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
            0x79e0000 -  0x7a06ff6 +com.adobe.AXE8SharedExpat AdobeAXE8SharedExpat 3.5.101.12783 (3.5.101.12783) <C7FD5306-E881-A19A-0F40-0E3844278526> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedEx pat
            0x7a19000 -  0x7a40fed +com.adobe.AXE16SharedExpat AdobeAXE16SharedExpat 3.5.101.12783 (3.5.101.12783) <13B60B50-7241-73D6-E551-6E2E3E0AD7ED> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16Shared Expat
            0x7a53000 -  0x7aabff7 +com.adobe.AdobeXMPCore Adobe XMP Core 5.2 -c 3 (61.141987) <31B045A8-AA5F-AFDF-E2DD-71B418CD1707> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
            0x7abb000 -  0x7b28fef +com.adobe.FileInfo.framework Adobe XMP FileInfo 5.2 -i 1 (debug) (61.141987) <ABF47D32-C58A-F9CE-E753-F0F906B13F7E> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
            0x7b45000 -  0x7ce4fe7 +com.adobe.owl AdobeOwl version 3.0.81 (3.0.81) <9C261D9E-9BD7-5DE6-5676-AEEF4828D17B> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
            0x7d4d000 -  0x8adefeb +com.adobe.psl AdobePSL 12.0.0.12659 (12.0.0.12659) <03D5B098-AD3C-FB84-0D0D-7DE57C025F3F> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
            0x8e46000 -  0x902cff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <AF804353-8B13-7180-F2C8-832361EB2D5A> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
            0x90ba000 -  0x90beffc +com.adobe.AdobeCrashReporter 3.0 (5.5.20101001) <EA9B7B55-7FE5-14D2-FBAE-817121F94086> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
            0x90c4000 -  0x9388ff3 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.150919) <54BE6966-C47D-08E4-D08A-36B4949DE849> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
            0x968d000 -  0x97e7fff +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.150919) <549A0950-E4E2-F867-2A0D-ABFC00A56E54> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
            0x993d000 -  0x9c5efe7 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.150919) <3F958167-F680-C012-8CCA-424B65E75F9C> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
            0xa124000 -  0xa192ffb +com.adobe.amtlib amtlib 4.0.0.21 (4.0.0.21) <3090D254-587A-A820-DBCD-729C27532FC8> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
            0xa1a9000 -  0xa1ffffb +com.adobe.headlights.LogSessionFramework ??? (2.1.2.1263) <5B594BC9-5222-651B-6B70-7AD067035B1A> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
            0xa248000 -  0xa27dfef +com.adobe.pip ??? (5.5.0.1265) <660E209C-F595-AB0B-FB5E-C8FC1527CF4D> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
            0xa288000 -  0xa3c0fe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
            0xa402000 -  0xa408ff3 +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.150919) <615D7334-B103-3FE9-2150-1BA67D6B541F> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
            0xa419000 -  0xa424fff +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.150919) <84E8374D-5DB8-E2F5-8677-D9D715FC04CE> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
            0xa438000 -  0xa4b7fff +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.150919) <DA8506EE-FC4B-7FE3-0B8B-75889386B07C> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
            0xa51b000 -  0xa525ffb +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.150919) <CFE6F1B2-7A2E-9D22-EE9F-267F765FE0F6> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
            0xa538000 -  0xa53aff3 +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.150919) <084DB300-4206-FDCD-EC2F-1D54F0A13E1D> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
            0xa542000 -  0xa54affb +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.150919) <79DF91DA-997F-5806-D847-667A7AE3FE6A> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
            0xa55a000 -  0xa6f7ff7 +com.adobe.AFlamingo AFlamingo 2.1.402.12783 (2.1.402.12783) <B34C21DA-5AF0-47BD-5375-375414ACC9CD> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
            0xa8c6000 -  0xa8c9ffc +com.adobe.ape.shim adbeape version 3.1.74.12761 (3.1.74.12761) <FE2ABE8A-1D3F-7AF5-297C-D22FC3E0FBDA> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
            0xa8d0000 -  0xa9e2ff7 +FlashIK Framework ??? (1.0) <8EB8A2F0-C7B0-63FC-28A0-D69E43B0AE92> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
            0xaa74000 -  0xaabaff7 +PFF Framework ??? (1.0) <8256E961-D8D3-0515-5FB9-A75C1D440923> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
            0xaae4000 -  0xb4e4fef +com.adobe.AFlame AFlame 1.1.5.12783 (1.1.5.12783) <842BEADF-C618-794C-DA88-3BE4C23A697F> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
            0xb6b7000 -  0xb6e0ff3 +com.adobe.contextui.framework contextui version 5.0.0 (5.0.0.150919) <3D09FEF1-1029-490D-0B74-9E54098EF9E3> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/contextui.framework/Versions/A/contextui
            0xb71c000 -  0xb720ff7  JavaLaunching ??? (???) <91BF8AB9-AFE3-F32B-B657-959C49CF4928> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
            0xb726000 -  0xb766ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
            0xb77f000 -  0xb834fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
            0xb87a000 -  0xb87dfe3 +com.adobe.dvaflashview.framework dvaflashview version 5.0.0 (5.0.0.150919) <318AE6D8-5D2E-B899-A4A9-40DBBED181BF> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
            0xb8f6000 -  0xb8f7ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
            0xbe78000 -  0xbee3fe7 +com.adobe.amt.services AMTServices 4.0.0.21 (BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00) (4.0.0.21) <018F21DE-7E2E-C850-4C32-D4A2131ABF74> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
            0xbeff000 -  0xbf6ffeb +com.adobe.adobe_caps adobe_caps 4.0.42.0 (4.0.42.0) <55D7D2EA-D21E-98B1-77C6-58C0A0E07051> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
            0xbf7a000 -  0xbf82fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
            0xbfb9000 -  0xbfbaff7  ATSHI.dylib ??? (???) <F06AB560-C2AF-09F6-7328-773E43CA2713> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
            0xbff9000 -  0xbffaff3 +com.macromedia.Flash.flastoragelib 9.0 (9.0) <841F9AEF-0220-C997-42CA-30BB849C5089> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
            0x21204000 - 0x21212fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <07211458-FD06-9FEF-3DF4-2E5F0304D4BC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
            0x21216000 - 0x21228ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8D606435-1A3C-FE0B-824A-1386809FFFF5> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
            0x2122c000 - 0x21230ff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <E9CB576C-283B-1DB2-0C69-E7C914BD7922> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
            0x2123e000 - 0x212fefff +net.sourceforge.webcam-osx.common 0.9.2 (0.9.2) /Users/JohnB/Library/QuickTime/macam.component/Contents/MacOS/macam
            0x21763000 - 0x21769ff7  com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
            0x21b8f000 - 0x22581ff3 +com.macromedia.Flash Player.authplaylib 10.2.153.2 (10.2.153.2) <3CFE191B-E5E1-6C47-46DB-FE24C06872B7> /Applications/Adobe Flash CS5.5/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
            0x226d9000 - 0x226d9ff0 +com.google.GearsEnabler ??? (1.0) <C5B680AD-0957-59FD-B95F-A79C89E04678> /Library/InputManagers/GearsEnabler/GearsEnabler.bundle/Contents/MacOS/GearsEnabler
            0x22bf1000 - 0x22bf3ff7 +com.macromedia.Flash.FLfile 11.5.0.325 (11.5.0) <21E1B8AE-CB7E-7019-218F-A9AC206C88B5> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
            0x22c03000 - 0x22c17ff7 +AdobeSFL ??? (???) <D6D44AC1-8AEC-56BB-8CDD-9059711B3485> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
            0x22c1d000 - 0x22c46fef +com.adobe.ape adbeapecore version 3.1.74.12761 (3.1.74.12761) <21548488-E9C3-4638-D7FC-895EE0F8EE30> /Library/Application Support/Adobe/APE/3.101/adbeapecore.framework/adbeapecore
            0x22c65000 - 0x22c9effb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 2.0.0.15 (2.0.0.15) <3A9CF871-6678-90BB-3770-CDBF56AF21D5> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificati ons
            0x22cce000 - 0x22cdeff3 +com.yourcompany.PointGrid ??? (1.0) <1572B151-C83B-B62E-A9C5-F741706082E5> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
            0x22e5d000 - 0x22e64ffb  libjvmlinkage.dylib ??? (???) <CEBF52ED-6F28-BC0E-A3F6-C1CCE925FB0A> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
            0x231e8000 - 0x231edff7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <31610F71-4447-CC8F-2859-4B881BB48F9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
            0x238d7000 - 0x238deff7  libverify.dylib 1.0 (1.0) <032F1D31-9879-044D-778B-44277CDA9BBB> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
            0x23f22000 - 0x23f2aff7  JavaNativeFoundation ??? (???) <DB43720B-D43B-26A9-AB19-6DCCB5732F3A> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
            0x24047000 - 0x2406afe7 +ServiceManager-Launcher.dylib 236.0.0 (compatibility 2.5.0) <F2933B29-0CC1-00B4-1778-BF44110851F8> /Library/Application Support/Adobe/CS5.5ServiceManager/lib/ServiceManager-Launcher.dylib
            0x240c6000 - 0x240e4ff7 +com.adobe.flash.cs55.airAndroid 11.5.0.0 (11.5.0) <7BFBDD83-2B68-53BB-0E0D-43C105CB5719> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/Air2_5_Android.bundle/Contents/MacOS/Air2_5_Android
            0x241a7000 - 0x241c9ff7 +com.adobe.flash.cs55.air 11.5.0.0 (11.5.0) <1329BBFC-ED3D-C787-92B6-A63177C2552B> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/Air2_5.bundle/Contents/MacOS/Air2_5
            0x241df000 - 0x241ebff7  libzip.jnilib ??? (???) <BAAB3F70-196A-60A9-9E75-5A9FB5989E3F> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
            0x2436d000 - 0x24389ff7  libjava.jnilib ??? (???) <9DACA27C-BFBB-58BF-281B-A0C0F9A813C4> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
            0x243a4000 - 0x24409fe7 +com.yourcompany.Brush ??? (1.0) <514A0F0D-DA07-9F32-B3A8-A1F1C12BF0E3> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
            0x24a79000 - 0x24b02ff7 +com.yourcompany.Collision ??? (1.0) <F7BEA1C6-99F5-FBA8-F960-20F7DC0CE06F> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
            0x252f9000 - 0x2533aff3 +com.adobe.flash.flbridge 11.5.0.325 (11.5.0) <72AC5C1A-8338-C772-EF75-D30229D44F9C> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
            0x2a7eb000 - 0x2a900fff +com.yourcompany.Stroke ??? (1.0) <2DCF3D57-AEF2-C4EB-8677-135673A4BE47> /Applications/Adobe Flash CS5.5/Common/Configuration/External Libraries/Stroke.bundle/Contents/MacOS/Stroke
            0x2d3cb000 - 0x2d704ff7  libjvm.dylib ??? (???) <463F6D7A-45CF-0F85-167A-18BB2879EB48> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libjvm. dylib
            0x40000000 - 0x400d1fe7 +com.adobe.JP2K 2.0.0 (2.0.0.12659) <88D70F2A-FFBA-EEB2-123D-42F4EB7CF4E3> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
            0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
            0x90042000 - 0x9004aff7  com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
            0x9004b000 - 0x9004bff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
            0x900b8000 - 0x90296feb  libType1Scaler.dylib ??? (???) <59FE1036-1BC2-1A8E-F7C6-E0CC15A4D6D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
            0x9029a000 - 0x9047cfff  com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
            0x9049f000 - 0x905a1fef  com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
            0x905a2000 - 0x905f2ff7  com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
            0x905f3000 - 0x905f3ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
            0x905f4000 - 0x905f6ff7  libRadiance.dylib ??? (???) <5920EB69-8D7F-5EFD-70AD-590FCB5C9E6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
            0x905f7000 - 0x90612ff7  libPng.dylib ??? (???) <25DF2360-BFD3-0165-51AC-0BDAF7899DEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
            0x90613000 - 0x90656ff7  libGLU.dylib ??? (???) <FB26DD53-03F4-A7D7-8804-EBC5B3B37FA3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
            0x90657000 - 0x90713fff  com.apple.ColorSync 4.6.6 (4.6.6) <7CD8B191-039A-02C3-EA5E-4194EC59995B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
            0x90714000 - 0x907c2ff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
            0x907c3000 - 0x90900fe7  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <2D31CC6F-32CC-72FF-34EC-AB40CEE496A7> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
            0x90901000 - 0x90d36ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
            0x90d37000 - 0x90d8ffe7  com.apple.datadetectorscore 2.0 (80.7) <A40AA74A-9D13-2A6C-5440-B50905923251> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
            0x90e00000 - 0x90e0cff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
            0x90ece000 - 0x90fdaff7  libGLProgrammability.dylib ??? (???) <04D7E5C3-B0C3-054B-DF49-3B333DCDEE22> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
            0x90fdb000 - 0x9142cfef  com.apple.RawCamera.bundle 3.7.1 (570) <AF94D180-5E0F-10DF-0CB2-FD8EDB110FA2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
            0x91539000 - 0x9158cff7  com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
            0x915ce000 - 0x916aefe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
            0x9178e000 - 0x917b6ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <315D97C2-4E1F-A95F-A759-4A3FA5639E75> /usr/lib/libxslt.1.dylib
            0x917b7000 - 0x9184ffe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
            0x91850000 - 0x9187aff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
            0x9187b000 - 0x91897fe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
            0x91898000 - 0x918a6fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
            0x918a7000 - 0x918eeffb  com.apple.CoreMediaIOServices 140.0 (1496) <DA152F1C-8EF4-4F5E-6D60-82B1DC72EF47> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
            0x918ef000 - 0x91907ff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
            0x91951000 - 0x91953ff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
            0x91989000 - 0x91e44ff7  com.apple.VideoToolbox 0.484.60 (484.60) <B53299EC-E30F-EC04-779D-29B7113CC14A> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
            0x91e8b000 - 0x91efaff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
            0x91efb000 - 0x91f10fff  com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
            0x91f11000 - 0x91f4eff7  com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
            0x91f4f000 - 0x91f63fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
            0x91f64000 - 0x92288fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            0x92289000 - 0x923b7fe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
            0x92496000 - 0x925bcfe7  com.apple.WebKit 6534.51 (6534.51.22) <8E713C26-E90D-0E4B-5FE1-7AFFA8DF2935> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
            0x925bd000 - 0x92601ff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
            0x92d28000 - 0x92d28ff7  com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
            0x92d29000 - 0x92dd5fe7  com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
            0x92dd6000 - 0x92ddcfff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
            0x92ddd000 - 0x92e3aff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
            0x92e7c000 - 0x92eddfe7  com.apple.CoreText 151.10 (???) <5C2DEFBE-D54B-4DC7-D456-9ED02880BE98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
            0x92ede000 - 0x92f23ff7  com.apple.ImageCaptureCore 1.1 (1.1) <F54F284F-0B81-0AFA-CE47-FF797A6E05B0> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
            0x92f34000 - 0x92f3afe7  com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
            0x92f3b000 - 0x92f45fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
            0x93089000 - 0x930cfff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
            0x930d0000 - 0x930d4ff7  libGIF.dylib ??? (???) <2123645B-AC89-C4E2-8757-85834CAE3DD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
            0x930d6000 - 0x93111feb  libFontRegistry.dylib ??? (???) <AD45365E-A3EA-62B8-A288-1E13DBA22B1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
            0x93112000 - 0x9311fff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
            0x93120000 - 0x932c7ff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
            0x932e9000 - 0x932f9ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
            0x932fa000 - 0x93347feb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
            0x93348000 - 0x93642fef  com.apple.QuickTime 7.6.6 (1787) <AC48EAD9-7201-7CE6-C826-41B12963FECF> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
            0x93643000 - 0x93644ff7  com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
            0x93645000 - 0x93688ff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
            0x93689000 - 0x939f4ff7  com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
            0x939f5000 - 0x93a19ff7  libJPEG.dylib ??? (???) <EA97DEC5-6E16-B51C-BF55-F6E8D23526AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
            0x93a1a000 - 0x93a1eff7  libGFXShared.dylib ??? (???) <801B2C2C-1692-475A-BAD6-99F85B6E7C25> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
            0x93a1f000 - 0x93a5dff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
            0x93a80000 - 0x93b74ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
            0x93bda000 - 0x93cdcfe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
            0x93cea000 - 0x93f15ff3  com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
            0x93f16000 - 0x93fb1fe7  com.apple.ApplicationServices.ATS 275.19 (???) <9FA31967-CF14-B033-EB8D-570561D12A13> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
            0x93fb2000 - 0x94223fef  com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            0x94224000 - 0x94325fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <C75F921C-F027-6372-A0A1-EDB8A6234331> /usr/lib/libxml2.2.dylib
            0x94326000 - 0x94329ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
            0x9432a000 - 0x943aafeb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
            0x943ab000 - 0x943e5ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <038731B1-CC44-3943-E3DE-4BAAA203EB72> /usr/lib/libcups.2.dylib
            0x943e6000 - 0x943edff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
            0x943ee000 - 0x94452ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
            0x9459d000 - 0x9459dff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
            0x9459e000 - 0x945a3ff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
            0x945a4000 - 0x945e8fe7  com.apple.Metadata 10.6.3 (507.15) <460BEF23-B89F-6F4C-4940-45556C0671B5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
            0x947f9000 - 0x947faff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <838E1760-F7D9-3239-B3A8-20E25EFD1379> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
            0x947fb000 - 0x94976fe7  com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
            0x94977000 - 0x949a7ff7  com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
            0x949a8000 - 0x94a23fff  com.apple.AppleVAFramework 4.10.27 (4.10.27) <BFD2D1CA-535C-F16F-0EB5-04905ABD65CF> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
            0x94af4000 - 0x94b6dff7  com.apple.PDFKit 2.5.1 (2.5.1) <CEF13510-F08D-3177-7504-7F8853906DE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
            0x94b6e000 - 0x94b7eff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
            0x95e53000 - 0x96642557  com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
            0x96834000 - 0x96854fe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
            0x96855000 - 0x96869ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
            0x9686a000 - 0x9686aff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
            0x9686b000 - 0x968d9ff7  com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
            0x968da000 - 0x9696cfe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
            0x969ec000 - 0x96a66fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
            0x96a67000 - 0x96a6afe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
            0x96a6b000 - 0x96a7cff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
            0x96a7d000 - 0x96ab3fff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
            0x96ab4000 - 0x96bf7fef  com.apple.QTKit 7.7 (1787) <3B47A1A0-7AB5-C1C9-42DE-5993D1012D47> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
            0x97255000 - 0x97260ff7  libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
            0x97261000 - 0x97273ff7  com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
            0x97274000 - 0x97311fe3  com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
            0x9731e000 - 0x98082fe7  com.apple.WebCore 6534.51 (6534.51.22) <1E9475BF-87F2-A81F-E096-BBB126BCDF30> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
            0x98083000 - 0x983a3ff3  com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
            0x983f4000 - 0x9849cffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
            0x9849d000 - 0x984c4ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
            0x984c5000 - 0x98502ff7  com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
            0x98557000 - 0x98561ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
            0x98562000 - 0x985abfe7  libTIFF.dylib ??? (???) <579DC328-567D-A74C-4BCE-1D1C729E3F6D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
            0x985ac000 - 0x9872efe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D5980817-6D19-9636-51C3-E82BAE26776B> /usr/lib/libicucore.A.dylib
            0x9872f000 - 0x9873aff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
            0x9889e000 - 0x988dfff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
            0x9898a000 - 0x989ccff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
            0x989cd000 - 0x989dbff7  com.apple.opengl 1.6.13 (1.6.13) <025A905D-C1A3-B24A-1585-37C328D77148> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
            0x989dc000 - 0x98df2ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
            0x98e2d000 - 0x98e36ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
            0x98e37000 - 0x98e37ff7  com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
            0x98e7c000 - 0x98e7fff7  libCoreVMClient.dylib ??? (???) <F58BDFC1-7408-53C8-0B08-48BA2F25CA43> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
            0x98e80000 - 0x98f5afff  com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
            0x9900c000 - 0x99016ff7  com.apple.HelpData 2.0.5 (34.1.1) <A9CF754F-B254-5D40-B8B5-F35414DFD875> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
            0x99017000 - 0x99099ffb  SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
            0x990c5000 - 0x991f2ffb  com.apple.MediaToolbox 0.484.60 (484.60) <A7FE2739-64A7-40EB-A6E7-69FBCE3C87D4> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
            0x991f3000 - 0x99249ff7  com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
            0x9924a000 - 0x9924aff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
            0x9924b000 - 0x9924fff7  IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
            0x9926d000 - 0x9926eff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
            0x9926f000 - 0x9928eff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
            0x99296000 - 0x992bcffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
            0x992bd000 - 0x992c0ffb  com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
            0x992c1000 - 0x992c1ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
            0x992c2000 - 0x992f5fff  libTrueTypeScaler.dylib ??? (???) <0F04DAC3-829A-FA1B-E9D0-1E9505713C5C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
            0x992f6000 - 0x99360fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
            0x99361000 - 0x99368ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
            0x993bb000 - 0x99474fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
            0x99475000 - 0x9952dfeb  libFontParser.dylib ??? (???) <D57D3834-9395-FD58-092A-49B3708E8C89> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
            0x99585000 - 0x995a7fef  com.apple.DirectoryService.Framework 3.6 (621.11) <CA979EAC-9537-43B6-CD69-C144ACB75E09> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
            0x995a8000 - 0x995d9ff7  libGLImage.dylib ??? (???) <0EE86397-A867-0BBA-E5B1-B800E43FC5CF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
            0x995da000 - 0x995fbfe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
            0x995fc000 - 0x996a9fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
            0x996eb000 - 0x998adfeb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <027F55DF-7E4E-2310-1536-3F470CB8847B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
            0x998ae000 - 0x998aeff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
            0x999e6000 - 0x99a40fe7  com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
            0x99a41000 - 0x99ca6feb  com.apple.security 6.1.2 (55002) <7F00A51B-F22A-0EBC-A321-923472D686BD> /System/Library/Frameworks/Security.framework/Versions/A/Security
            0x99cb1000 - 0x99d7cfef  com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
            0x99dec000 - 0x99e1fff7  com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
            0x99e20000 - 0x9a069ffb  com.apple.JavaScriptCore 6534.51 (6534.51.21) <EA8C05E3-4719-B3FA-E17E-EC9BBC09F5B2> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
            0x9a16e000 - 0x9aa51ff7  com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
            0xb0000000 - 0xb0011ff8 +com.adobe.ahclientframework 1.6.0.20 (1.6.0.20) <6FB288F2-45FD-E54A-C9A4-A0D0C374FE37> /Applications/Adobe Flash CS5.5/Adobe Flash CS5.5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
            0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <B339B85B-1B6D-81D8-1281-7B8C8A517329> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
            0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <EF3E3210-927F-DB9F-4CD4-4039A2AE2F84> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
            0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
