16 Replies Latest reply on Apr 11, 2011 9:31 AM by Jean Pierre Bottazzoli
    Why am I getting Horizontal Lines in CS5 Output and How to Fix?
    Dad From Minnie
      Greetings. I have editted of AVCHD video shot from a Sony Camcorder (HDR-CX550 shot at HD HQ mode (9M)) in Premiere Pro CS5. Frame rate is 29.97 fps, at 1440 x 1080 (1.33) . My subjects are hockey players, so there is a lot of natural contrast in the video (white ice and dark unifroms). I believe a major contributing factor is that I have significanly slowed these shots down so that I can do a side-by-side analysis of skating form. The output has horizontal lines distorting edges (see bottom)
      I suspected that the problem was interlacing artifacts, but when I play with Blending, De-interlacing, Removing Flicker (options in the Field Options), the problem isn't removed, and sometimes the output is made worse. The problem  is most pronounced after making the output file (DVD Standard is shown).
      Do you have any ideas one  why this is happening and how to resolve it?
      Thanks much!
        • 1. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
          Todd_Kopriva Level 8
          That is definitely a problem with interlacing. See this page for information about deinterlacing.
          • 2. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
            Dad From Minnie Level 1
            Todd. I think you are right. My issue may not be with Premiere Pro. It
            looks  perfect in Premiere Pro, but when I create a DVD in encore, it gives
            me the results show in that screen shot. When playing around in Premiere
            Pro, I changed the sequence option from "Display First Field" to "Display
            Both Fields" and the quality immediately degraded in Premiere Pro to the bad
            quality in the screen shot.
            Is Premiere Pro compensating for the Interlacing, but Encore is not?
            Do you know if there is some option or setting in Encore that would allow me
            to create the crystal clear output, the same as what I am seeing in Premiere
            Pro?
            Thanks.  Tim
            • 3. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
              Jeff Bellune Level 5
              Please don't double-post. It'll just confuse everyone, including those who visit here later.  You've been told that the artifacts you are seeing are a result of interlaced source footage.  It's not an Encore-specific issue, nor is it Premiere-specific.  You can go further in-depth on what exactly you want your audience to be able to see and do with the video from Pr to get more advice on how to proceed.  I deleted your Encore topic.
              -Jeff
              • 4. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                Sorry about the double post. I wasn't sure the audience would be right when
                I start going down a path that isn't really about Premiere Pro... Tim
                • 5. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                  Thanks, Todd. I read the linked-to information and I think you are right. However, I didn't really see an answer in there as to  how to avoid this problem, although I may have missed it.
                  I am hoping for a clarification for  how to resolve this when burning DVD's (and Blu Ray) disks.
                  Thanks.
                  • 6. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                    Jim_Simon Level 8
                    Describe your process of getting the HD video into Encore for SD DVD authoring.
                    • 7. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                      Hi Tim,
                      I also would like to know how you intend for your audience to use this DVD/BD.  Will they sit back and enjoy it on their new HDTV?   Will they watch it on their old NTSC CRT television?  Will they play it on their computers to go frame-by-frame to analyze skating techniques?
                      If all they'll do is watch, then you need to keep your interlaced video interlaced, and keep the field order intact.  If you need this to be analyzed, then you may want to consider deinterlacing the video.  However, most HDTVs, and most software DVD players can deinterlace the video on playback so that frame-by-frame looks good even if the video on the DVD is interlaced.
                      If you can achieve what you need without deinterlacing the video in Pr (including export from Pr) then I recommend leaving things as they are and just burn the DVDs.  Same for BD.
                      -Jeff
                      • 8. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                        • 9. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                          Hi Jeff: Like most real-world projects, the viewers would use a variety of devices: Big screen HDTV, medium TV (NTSC definitely, CRT maybe), and a computer.
                          Frame by frame analysis to a degree... They will be able to see much by virtue of the slow-motion speed; and they will, more than likely, want to stop  the clip at certain spots to allow a closer look...
                          This is frustrating because I have left it as interlaced, and it appears very clear in  Premiere Pro, but when I cut the DVD, that is where I see the problems... I understand there may be technical reasons as to why, but it seems like if I can see it nicely in Premiere Pro, I should be able to also see it nicely in the DVD/Blu-Ray (which is why I thought there must be some setting I was missing that  caused the problem, either in Premiere Pro or Encore).
                          Is the answer, then, that in order to slow it down adequately, I need it de-interlaced... or, I need to  actually use a video camera that can take slow-motion clips (60p rather than 60i?)?
                          I looked at some of your videos (on your website), Jeff, and clearly, you are a man who knows a lot about this topic, so I do look forward to your input.
                          Thanks.
                          • 10. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                            Small steps first:
                            • How is your Program Monitor set to display timeline content: first field, second field or both fields?  If it's not set to both fields, then you won't see any interlacing artifacts because only one field is displayed at a time.  You mentioned changing this setting earlier, so you should understand why the artifacts appear/disappear when the setting is changed.
                            • How are you viewing the finished DVD/BD when you see the artifacts?  Are you using an HDTV?  Are you using a software DVD player on your computer?  Or are you just using a media player?
                            -Jeff
                            • 11. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                              Jeff: The Program Monitor is set to First Field.  When I switched it to
                              Both, that is when I saw the problems, as you noted.
                              I seem the artifacts on DVD and BD versions on HDTV.
                              I see the artifacts on my PC when using Media Player.
                              I see the artifacts on my PC when I run using  CyberLink PowerDVD. Checked
                              its configuration and found an option called Smart De-Interlacing Mode,
                              which had the Perform de-interlacing option checked. When I unchecked that,
                              the interlacing became MUCH worse, so I believe both  Media Player and
                              CyberLink PowerDVD are both doing something  to avoid some degree of
                              interlace artifacts.
                              Thanks. Tim
                              • 12. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                                function(){return A.apply(null,[this].concat($A(arguments)))}
                                My guess is that your troubles start somewhere in those 2 steps.
                                Suggestions:
                                • Leave the Sony software completely out of the process.
                                • That camera doesn't shoot AVCHD.  It shoots MPEG-4 using H.264/AVC.  There is a real and significant difference between the two.
                                • Determine for sure whether you have 1920x1080 or 1440x1080 footage.  The camera specs say 1920x1080.
                                • Import the clips via the Pr Media Browser.
                                • Make sure Pr sees the clips as 1920x1080/60i.
                                • Drag a clip to the New Item icon at the bottom of the project panel to create a proper sequence that matches the clip's properties.
                                -Jeff
                                • 13. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                                  Jeff: The Sony HDR-CX550 does shoot AVCHD... At least, that's what the
                                  labeling on the device says, and so does the documentation that came with
                                  it.  If I look at the properties of one of the imported .m2ts files (via
                                  PMB), it shows Type of File as AVCHD Video (m2ts).
                                  The footage I have in my current project is 1440x1080 (1.333); it is
                                  unaltered, as far as I can tell, other than it was transferred from the
                                  camcorder to the PC via Sony's PMB (if that altered it... not sure).
                                  I am not sure I can leave Sony's PMB software out of it... How else do I get
                                  the video out of the camcorder? Are you saying that Premiere Pro has the
                                  capability to extract video files directly from the camcorder?
                                  I have used both the Media Browser and direct import into the Project and
                                  there doesn't seem to be any difference in the video.
                                  The reason I believe the problem came after the import into Premiere Pro is
                                  because Premiere Pro can seem to replay the video  fine, which makes me
                                  believe the problem is downstream (workflow-wise) from the retrieval from
                                  the camcorder and importation into Premiere Pro.
                                  Thanks. Tim
                                  • 14. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                                    M2TS files are not AVCHD.  True AVCHD files have MTS extensions.  It's possible that the PMB software is converting the AVCHD video to Blu-ray video streams, which do have an M2TS file extension.  It may do that to make the files "play back friendly" for Blu-ray players.
                                    If the camera does record true AVCHD, then the memory card/flash memory will have a folder called PRIVATE that has all of the bits and pieces needed for AVCHD video.  Just copy the PRIVATE folder from your memory card/flash memory to your hard drive.  Then use the Media Browser in Pr to navigate to the copied PRIVATE folder.  As soon as you do that, all of the clips will magically appear in the Media Browser; import the AVCHD video into your project.
                                    It may seem like I'm splitting hairs here, but there's no way to know exactly what the PMB software is doing to the video before it gets to Pr.  That's why I think it's so important to eliminate the PMB software from the process.
                                    -Jeff
                                    • 15. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                                      Unfortunately, for this particular footage, I have already deleted it from
                                      my camcorder and cannot get to it. However, using your suggestion, I was
                                      able to find the MTS (non-container) avchd files. I didn't find it in the
                                      Private folder, though... My MTS files were in the AVCHD/BDMV/STREAM folders
                                      in the camera.
                                      I will experiment with footage to see if when I slow it down it makes any
                                      difference in the DVD.
                                      One other thing I noticed. When I created an MPG (export/media) from
                                      Premiere Pro (same settings as source file) against my original .m2ts files,
                                      the resulting file does show some artifacts when viewed locally using
                                      Windows Media Player. However, when I load the same file to YouTube, the
                                      artifacts disappear and it looks very good, even full screen during the very
                                      slow-motion parts (e.g. 44 seconds into the clip, slow motion, straight
                                      away).
                                      The following link will show what I mean:  http://youtu.be/XIYjxPYkzhM
                                      It seems like what I play these clips on is key... so, how do I get
                                      that better quality (removing the artifacts), when creating a DVD... It
                                      seems like the pieces are there, or the  youtube clip wouldn't look
                                      better...
                                      Thanks so much for sharing your insight. Tim
                                      • 16. Re: Why am I getting Horizontal Lines in CS5 Output and How to Fix?
                                        Good Day Jeff,
                                        It's out of subject, but thanks for the informations about Sony Content Manger and .MTS .m2ts file extensions.
                                        Regards, JPB
