3 Replies Latest reply on Mar 27, 2011 7:38 AM by kglad
    AS2 8 digit color values
    StanleyR2001
      I have an AS2 flash web site which has the following color values defined in the ActionScript :
      Stage.addListener(StageL);
      var txtFormat2 = createTF(24, 10066329, 2, 8, false);
      var txtFormat3 = createTF(14, 3355443, 1);
      var txtFormat4 = createTF(11, 11184810, 1.500000E+000);
      var txtFormat5 = createTF(10, 7829367, 2);
      var txtFormat6 = createTF(11, 12632256, 1, 6);
      var txtFormat67 = createTF(12, 11184810, 1, 8);
      var txtFormat7 = createTF(12, 4539717, 1);
      var txtFormat8 = createTF(10, 10066329, 1);
      var txtFormat11 = createTF(10, 4539717, 1);
      var txtFormat9 = createTF(11, 10066329, 1.500000E+000);
      var whiteFormat = new TextFormat();
      whiteFormat.color = 13421772;
      var darkFormat = new TextFormat();
      darkFormat.color = 6710886;
      var centerTxt = new TextFormat();
      I thought the 8 digit color values represented ( first 2 digits = transparency value, remaing 6 digits = RGB values ).
      Could you verify if the above statement is correct ?
      If not correct, could you explain how to interpret the 8 digit color values and recommend a chart or color conversion
      tool which will provide a visual representation of each color value ?
