5 Replies Latest reply on Apr 3, 2011 12:37 PM by ashutoshmehra
    Reader X, sandbox and SendMessage()
    erankro
      Hi.
      How can I keep my plugin running under Reader X, without disabling the protected mode?
      At some point in my plugin code I use SendMessage() with WM_COPYDATA to send some data to my main proccess.
      My main process response to this message by poping a window....
      BUT because of the new "protected mode" I get error code of 1400 (which means Invalid window handle) when the
      command SendMessage() executes. I checked with Spy++ the window handle is valid of course.
      When I disable the protected mode the plugin work perfect (like it used to work in Acrobat 9,8,7...)
      I read everything on the policy file that should be set for the process broker. I wrote on but it doesn't help me because
      I don't need to run a process, nor writing a file or writing to a registry - I just need SendMessage() to work!
      I dowloaded SDK X and found no samples no documentation on that - how come?
      I read somewhere that an API ADDRULE(...) should be used to config the broker but found nothing on that in the SDK.
      Is there a chance to make it work? again - without disabling the protected mode but just make a specific request to the broker to allow
      my api call get through ?
      thanks a lot
      eran
