3 Replies Latest reply on Apr 7, 2011 7:31 AM by Frustrated in AZ
    Hello, can you tell me how I transfert my book from my adope digital Editions to my e-book Aluratek?
    charlau1
        • 1. Re: Hello, can you tell me how I transfert my book from my adope digital Editions to my e-book Aluratek?
          Level 4
          I'm going to assume that you've registered your Aluratek and updated its
          software to the latest level from its mother site on the web.  If you have,
          your problem might be just a case of doing things in the 'right' sequence.
          First, turn on and plug in your Aluratek and make sure that your computer
          recognizes it.  If you have a Windows machine, it will detect 'new hardware'
          the first time you do this, and will show you a message box when Windows has
          finished installing it.  Your Aluratek will display a message that it's on
          line also.
          When your Aluratek is on line, open ADE.  As it initializes, ADE looks for
          ebook readers that it recognizes among the devices that are attached to the
          computer.  When it finds your Aluratek, it will show it in the left hand
          panel of the Library View screen.  You then can drag and drop your book to
          your Aluratek.  ADE will show you a progress panel as it copies your ebook
          to the Aluratek.
          Finally, you need to disconnect your Aluratek electronically, not
          physically, from ADE by ejecting it.  Right click on the word Aluratek in
          the left hand panel, and then click on Eject.  When finished, the word
          Aluratek will disappear from the panel, and you can close ADE.  After it
          closes, you can disconnect your Aluratek from the computer, but don't turn
          it off!  The Aluratek needs to update its internal catalog with the new
          ebook.  It will tell you when that's done, and then you can turn the
          Aluratek off, or go to its Home page and see the ebook in its library.
          Then, you can start reading the book.
          Hope this helps!
          • 2. Re: Hello, can you tell me how I transfert my book from my adope digital Editions to my e-book Aluratek?
            phoppe
            I am having pretty much this same problem.  some of the sample files are DRM and some are not.  The ones that are DRM give me an error that I do not have permission to copy here.  The non DRM files work fine.  Any ideas?  This purchase is turning into a nightmare....
            • 3. Re: Hello, can you tell me how I transfert my book from my adope digital Editions to my e-book Aluratek?
              Level 4
              For background: each ePub document has permissions embedded into it.  You
              can see those when you use Library view in ADE, highlight the document and
              then click on the arrow in the document's label.  You'll get a drop-down
              menu (Item Options) that includes a tab marked 'Item Info'.  Clicking on
              that will display the permissions for that document.  If you're transferring
              documents that are not ePub, then you don't have this feature.
