3 Replies Latest reply on Mar 29, 2011 4:49 AM by Ned Murphy
    error 1034
    charles_ccent
      Any help would be great.
      import fl.motion.MotionEvent;
      import flash.events.MouseEvent;
      function calculateTotal(evtObject:MotionEvent):void
          var price:Number;
          var totalCost:Number;
          var numberOfJerseys:Number;
          if (jerseyType.text == "1")
              price = 10;
          if (jerseyType.text == "2")
              price = 12;
          if (playerNames.text == "Y" || playerNames.text == "y")
              price +=  1.50;
          numberOfJerseys = int(numberOfPlayers.text) + int(numberOfCoaches.text);
          totalCost = numberOfJerseys * price;
          total.text = String(totalCost);
      calc_btn.addEventListener(MouseEvent.CLICK, calculateTotal);
      error is:
      TypeError: Error #1034: Type Coercion failed: cannot convert flash.events::MouseEvent@3310f559 to fl.motion.MotionEvent.
      charles_ccent
        • 1. Re: error 1034
          Your events are not in agreement... the function is getting a MouseEvent but you say it's a MotionEvent
          • 2. Re: error 1034
            charles_ccent Level 1
            Thank You that helped with the error.
            Now when I use "y" it caculates the total 1, if I enter "n" it calculates correctly.
            Any suggestions. I'm using Flash CS5
            • 3. Re: error 1034
              I don't see anything wrong with the code that would lead to that error, though if you are declaring numberOfJerseys as a Number, then you may as well cast the number of players and coaches as numbers as well.  If the code you are now using differs from what you showed, then I cannot tell what you might have changed to make it work as you say it does.
