2 Replies Latest reply on Jul 3, 2006 8:11 AM by Newsgroup_User
    testing server setup
    Level 7
      Hi
      I'm using XPPro with IIS5.1
      If I startup IIS and create a new virtual directory by right clicking on the
      default web site.
      I then select a name and type in the path to where my site files are held.
      If I then startup DW define a site and select testing server and select:
      asp/java
      make my testing server folder the same as I set in IIS and then set the URL
      prefix to
      http://localhost/the name I set in IIS I assumed all would work however I
      get the wonderful
      The site URL prefix [/difulcher] for the testing server does not match the
      site url prefix [] specified in the http address for the site
      Where am I going wrong?
      thanks
      Ian
        • 1. Re: testing server setup
          Level 7
          http://www.webthang.co.uk/tuts/tuts_dmx/dmxf_1/dmx1_3.asp
          "Ian Edwards" <i.edwards@edwards-micros.co.uk> wrote in message
          news:e8b3va$7v2$1@forums.macromedia.com...
          > Hi
          > the default web site.
          > asp/java
          > URL prefix to
          > get the wonderful
          > thanks
          > Ian
          • 2. Re: testing server setup
            Level 7
            Thanks for that followed it to the letter and it works.
            Question though, it appears that if you are using the testing server then
            you are unable to use the built in ftp client?
            cheers
            Ian
            "twocans" <buyme@guinness.com> wrote in message
            news:e8b681$anp$1@forums.macromedia.com...
            >> Hi
            >> held.
            >> asp/java
            >> URL prefix to
            >> get the wonderful
            >> the site url prefix [] specified in the http address for the site
            >> thanks
            >> Ian
