0 Replies Latest reply on Mar 28, 2011 4:44 PM by theDavePld
    Old BlackMagic Extreme with CS5
    theDavePld
      Hi there,
      I'm trying to hook up an old BMC extreme PCI-X (Not PCI-e) on a PC machine based on Intel i7 960, Asus P6X58D Premium, and a QudroFX1800 graphic card, running Windows 7 64bit Ultimate edition. the driver installed just fine with no spacial issues, I can access the control panel, and it recognize the card by its Name. When I switch the input from Composite to component I see the monitor responding accordingly. so far so good, but when i'm trying to view an after effects CS5 composition via the card, all I get is Black (not Blank) signal no matter what kind of setup i choose from the adobe preferences menu. Same goes to Premiere CS5. I tried several file formats, from DV PAL, to Blackmagic 10/8 bit YUV/RG
      I tried with great success to view any composition via the adobe built-in DV out put module.  All software/drivers are updated to their latests versions.
      I've tried 2 cards like that, with same results.
      Is there a compatibility issue here? or, Am I doing something wrong?
      Thnaks for your time.
