9 Replies Latest reply on Mar 29, 2011 5:06 PM by mick.powell
    MXML vs ActionScript 3 - Which to use?
    IndieMusicScene Level 1
      So I'm a pretty strong ActionScript 3 programmer now.  I've been doing all my programming through Flash CS4.  I downloaded the Flash Builder 4 trial version and was getting a start on that, but I had a few questions.
      First is, is there really any advantage to using MXML over a strictly AS3 application?
      Second is, for my particular needs is there any reason to use any MXML at all?  So what are my needs?
      My application will be somewhat large and access a database of product information.  It will also be multilingual.  So almost any text or image that is displayed will be dynamic.  Also, positioning of objects will depend heavily on specific options and data availability.  Because just about everything in it will be dynamic, MXML seems pretty useless in my specific case, but perhaps others have some insight into this.
      I'd be completely happy doing it all in pure AS3, but since I work in a company and what I write will be used by others too, I want to make the right decision in creating this framework and not just go by personal preference.
      Thanks!
        • 1. Re: MXML vs ActionScript 3 - Which to use?
          UbuntuPenguin Level 4
          MXML allows you to create and change visual components very quickly without a whole lot of nonsense. Of course you could write everything in AS3, but that logic leads us to writing applications in asm, which no one does. Most importantly, components "out-of-the-box" lend themselves better to the changing world of requirements as opposed to hand written stuff.
          In your description of your application, I didn't really see anything that would say "Don't use MXML".   Flex apps using MXML are used to do all of the above and much more,  you should checkout Tour de Flex and look at the source code.
          PS. The two technologies aren't mutually exclusive, MXML compiles down to AS3, you can use the keep-generated-something-I-forget option to see what it is actually doing.
          • 2. Re: MXML vs ActionScript 3 - Which to use?
            Well... you make a strong argument!
            I downloaded Tour de Flex so I'll check that out.
            So... in my case, I guess I'd build out the framework in MXML, then dynamically populate/turn on/off objects in AS3 after the fact then?  I'll give it a go and see how that works out for me.
            Thanks UbuntuPenguin!
            • 3. Re: MXML vs ActionScript 3 - Which to use?
              Lee Burrows Level 4
              hi
              an important point to remember is that MXML IS ActionScript - just written in a different form. When you compile a flex app, the MXML is converted to AS and then the AS is compiled. (if you add -keep-generated-actionscript to the compiler options you can see all the AS files that are created)
              • 4. Re: MXML vs ActionScript 3 - Which to use?
                Oh yeah, I'm aware of that but thanks for the reminder!  I'm just thinking about how to write out all the code.  Is that normally how it's done?  MXML skeleton then use ActionScript in another file to do all the logic for it?  Or would the ActionScript be included in the same MXML file?
                Guess I'll have to get started on the tutorials!
                I still like the idea of writing it all in pure AS3 but... guess I have to get with the times.
                Thanks for all the input!
                • 5. Re: MXML vs ActionScript 3 - Which to use?
                  Lee Burrows Level 4
                  you can include the AS inside a script tag in the MXML file but yeah, its best practise to seperate the logic into another file.
                  as a side note, if you are doing mobile work then its best to avoid MXML as much as possible (for performance)
                  • 6. Re: MXML vs ActionScript 3 - Which to use?
                    mick.powell
                    There's a method called "coding behind" which tends to be the thing that gets touted when working in Flex the most and one that's work googling. I think the key here is what Ubuntu Penguin was talking about - the visual side of stuff. If you're using sub-classes of Flex components for your on screen components use MXML. You can code in Actionscript inside those files, you can use AS3 interfaces in MXML files as well (using  implements=), and you can sub-class. So you basically get everything you get in pure AS3 anyway, with some minor overhead from what the Flex Compiler needs to do (the major overhead being the actual Flex framework code itself!).
                    However, for all you backend stuff (remote objects, xml reading and generation, and all the non-visual stuff) I would stick with custom classes in AS3. Do remember though there is a "gotcha" with events in custom classes - if you want them to bubble you will need to do the bubbling yourself! Taking that into consideration though this is the path that I've adopted and that I would reccomend.
                    • 7. Re: MXML vs ActionScript 3 - Which to use?
                      pauland Level 4
                      ..that's news to me. It matters not whether you have custom classes or any other class - events work the same way.
                      • 8. Re: MXML vs ActionScript 3 - Which to use?
                        mick.powell Level 1
                        Sorry - let me qualify that - "custom classes that are not part of the
                        display object hierarchy". Eg Create you own custom class that doesn't
                        extend anything but that Implements iEventDispatcher - Create another class
                        that will be a child of the first (again implementing IEventDispatcher) -
                        fire an event using dispatchEvent on an instance the child class - the
                        instance of the parent class will not get the event, even though you have
                        added a listener and the event is bubbling. Unless something has changed
                        recently, that has always been the case.
                        • 9. Re: MXML vs ActionScript 3 - Which to use?
                          mick.powell Level 1
                          And by "added a listener" I mean added a listener to the parent - not the
                          child.
