2 Replies Latest reply on Mar 28, 2011 10:11 PM by huangxinghui
    TextField problem
    huangxinghui
      use TextInput, when input too many words, the textField.scrollH will be change
      then set the text property, textField.scrollH will be revert to 0 ?
      but sometime it is not, the textField.scrollH will not change to 0, so the content can not see
      why?
      example code:
      MyTextInput.as
      override public function set text(value:String):void
          super.text = value;
          if (textField)
              trace("scrollH=" + textField.scrollH);
      TextInputExample.mxml
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical"
       xmlns:component="component.*">
          <mx:Script>
              <![CDATA[
                  private function changeHandler():void
                      textInput.text = 'aa';
         </mx:Script>
         <component:MyTextInput id="textInput" width="100" text="asdf"/>
         <mx:Button label="Change" click="changeHandler()"/>
      </mx:Application>
      Thanks a lot.
        • 1. Re: TextField problem
          Flex harUI Adobe Employee
          Set horizontalScrollPosition = 0 when setting the text.
          • 2. Re: TextField problem
            huangxinghui Level 1
            Thanks for you reply.
            set horizontalScrollPosition=0 can solve the problem.
            but it is strange, so i change MyTextInput like this
            public class MyTextInput extends TextInput
                override protected function commitProperties():void
                    trace("begin scrollH=" + textField.scrollH);
                    super.commitProperties();
                    trace("after scrollH=" + textField.scrollH);
            when input too many word, the textfield scrolled. Then set text="aa"
            the console trace:
            begin scrollH=96
            after scrollH=0
            seem textField set text will change the scrollH=0 by itself, but sometime it is not.
            the flash player version is WIN 10.0.32.18
