1 Reply Latest reply on Mar 29, 2011 12:56 PM by Andrey V Branched from an earlier discussion.
    Premiere Pro hang on export
    buraihan Level 1
      I have been seeing this too. I edit on a mac pro:
      Intel Dual Quad core
      24 gb DDR2 SDRAM
      NVIDIA GeForce 8800 GT, Dual monitors
      OSX 10.6: Snow Leopard
      CS5 all updates applied.
      Every time I export within PPro, the file exports perfectly but then PPro freezes on completion and I have to force close it. I have been working on a SD widescreen DV based project and exporting to "1080i 1/4 resolution h.264 m4v" flash files.
        • 1. Re: Premiere Pro hang on export
          Andrey V Level 2
          Well, first of all you cannot make higher res video from low res. You cannot upsize frame from 720 to 1080 and get good quality, your immage will be pixelated.
          Second of all the data rate is different in two formats you mentioned.
          So that is probably why your premiere hangs. It is trying to import your transcodes back into project panel but could not understand the format and data rate.
          You can disable import fiture after transcode, but your video will not look good.
          Good luck
