1 Reply Latest reply on Mar 29, 2011 12:27 PM by Ned Murphy
    redcue 242k to 40k
    TM00 Level 1
      How can I reduce my swf from 242 to 40k when I've already compressed all the images, compressed my swf, and I aslo manually have the jpgs to 70
      *note I'm also using 2 tweens from flasheff 2.0...
      Thank You
        • 1. Re: redcue 242k to 40k
          You can probably generate a size report to see what's contributing to the weight of the file and then see where you need to focus your downsizing.  To generate the report go into your Flash Publish Settings and select the Generate Size Report option... then publish and see how things add up.  YOu might find you need to alter/remove some significant elements to get the size down where you intend.
