0 Replies Latest reply on Mar 29, 2011 11:16 AM by Eli7BBB
    full_scale, zoom and scroll pane question
    Eli7BBB
      I have an application which should be able to do full screen. BUT, only part of the stage should go full screen, some parts stay the same. (like all facebook games, where the friends_bar etc stay the same size).
      I want to be able to scroll-pane the background of the app in full screen the same way I do in normal mode...
      And I want to be able to zoom, and keep scrolling by draging the mouse.
      Going full screen works ok and so does the scroll-pane. BUT when I zoom in full screen - the scrolling does not behave correctly.
      I assume this is because - full screen does one change in scale and zooming adds to this change in scale again, but I dont know how to calculate both changes when I calcualte the borders of the scroll.
      Again - I am re-scaling when I go full screen manualy.
      I am attaching a small fxp which demonstrates the problem.
      The main tests.mxml
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/mx" minWidth="760" minHeight="642"
      width="
      760" height="642" initialize="application1_initializeHandler(event)">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Script>
      <![CDATA[
      import Classes.Screen;
      import flash.display.Sprite;
      import flash.display.Stage;
      importflash.display.StageDisplayState;
      importflash.events.MouseEvent;
      import flash.geom.Rectangle;
      importmx.core.BitmapAsset;
      importmx.core.UIComponent;
      importmx.events.FlexEvent;
      private var_fullScreenScale:Number;
      private varmain:UIComponent;
      private varinFullScreen:Boolean;
      private varlogMsgBox:TextField;
      public function getfullScreenScale():Number
      return_fullScreenScale;
      private functionenterFullScreen(e:MouseEvent):void
      if(inFullScreen == false)
      varredSquare:Sprite = e.target as Sprite;
      varw:int = (e.target asSprite).width;
      varh:int = (e.target as Sprite).height;
      varfullScreenRect:Rectangle = newRectangle(redSquare.x, redSquare.y, redSquare.width, redSquare.height);
      stage.displayState = StageDisplayState.FULL_SCREEN;
      var scaling:Number = 1;
      if(this.width > this.height)
      scaling = stage.stageWidth /
      this.width;
      else
      scaling = stage.stageHeight /
      this.height;
      _fullScreenScale = main.scaleX = main.scaleY = scaling;
      stage.align = StageAlign.TOP_LEFT;
      this.stage.addEventListener( FullScreenEvent.FULL_SCREEN, leaveFullScreen );
      inFullScreen = !inFullScreen;
      logMsgBox.width = 1000;
      logMsgBox.height = 500;
      else
      leaveFullScreen();
      private functionleaveFullScreen(event:FullScreenEvent=null):void
      this.stage.removeEventListener( FullScreenEvent.FULL_SCREEN, leaveFullScreen );
      this.stage.displayState=StageDisplayState.NORMAL;
      main.scaleX = 1;
      main.scaleY = 1;
      public functionlog_msg(str:String):void
      logMsgBox.appendText(str);
      "\n");
      logMsgBox.scrollV = logMsgBox.maxScrollV;
      private functionzoomIn(event:MouseEvent):void
      (main.getChildAt(0)
      asScreen).zoomIn();
      private functionzoomOut(event:MouseEvent):void
      (main.getChildAt(0)
      asScreen).zoomOut();
      protected functionapplication1_initializeHandler(event:FlexEvent):void
      varformat:TextFormat = newTextFormat();
      format.size = 20;
      format.color = 0x0000ff;
      // TODO Auto-generated method stub
      main =
      newUIComponent();
      main.graphics.beginFill(0xFF88CC);
      main.graphics.drawRect(0, 0, 955, 600);
      this.addElement(main);
      varredSquare:UIComponent = newUIComponent();
      redSquare.graphics.beginFill(0xFF0000);
      redSquare.graphics.drawRect(0, 0, 20, 20);
      redSquare.x = 50;
      redSquare.y = 50;
      redSquare.addEventListener(MouseEvent.CLICK, enterFullScreen);
      redSquare.buttonMode =
      true;
      this.addElement(redSquare);
      inFullScreen =
      false;
      varblueSquare:UIComponent = newUIComponent();
      blueSquare.graphics.beginFill(0x0000ff);
      blueSquare.graphics.drawRect(0, 0, 20, 20);
      blueSquare.x = 150;
      blueSquare.y = 50;
      blueSquare.addEventListener(MouseEvent.CLICK, zoomIn);
      blueSquare.buttonMode =
      true;
      this.addElement(blueSquare);
      vargreenSquare:UIComponent = newUIComponent();
      greenSquare.graphics.beginFill(0x0000ff);
      greenSquare.graphics.drawRect(0, 0, 20, 20);
      greenSquare.x = 200;
      greenSquare.y = 50;
      greenSquare.addEventListener(MouseEvent.CLICK, zoomOut);
      greenSquare.buttonMode =
      true;
      this.addElement(greenSquare);
      varlogMsgUI:UIComponent = newUIComponent();
      logMsgBox =
      newTextField();
      logMsgBox.width = 400;
      logMsgBox.height = 300;
      logMsgBox.background =
      true;
      logMsgBox.backgroundColor = 0xFFF000;
      logMsgBox.alpha = .5;
      logMsgBox.setTextFormat(format);
      logMsgBox.defaultTextFormat = format;
      logMsgBox.backgroundColor=0xffffff;
      logMsgBox.border =
      true;
      logMsgBox.borderColor = 0x000000;
      logMsgUI.addChild(logMsgBox);
      logMsgUI.x =
      this.width - logMsgBox.width;
      logMsgUI.y = 0;
      this.addElement(logMsgUI);
      log_msg(
      "init");
      varscr:Screen = new Screen();
      //main.graphics = greenRect;
      // create red square on stage, turn it into a button for going to full screen
      main.addChild(scr);
      </fx:Script>
      </s:Application>
      __________________________________________________________________________
      The Screen Class
      package
      Classes
      import flash.display.Bitmap;
      importflash.display.DisplayObject;
      import flash.display.Loader;
      import flash.events.Event;
      importflash.geom.Point;
      importflash.media.SoundChannel;
      importflash.media.SoundTransform;
      importflash.net.URLRequest;
      importflash.utils.Dictionary;
      importmx.binding.utils.BindingUtils;
      importmx.core.FlexGlobals;
      importmx.resources.ResourceManager;
      importmx.utils.NameUtil;
      public classScreen extends Sprite {
      public static var SCREEN_WIDTH :Number = 760;
      public static var SCREEN_HEIGHT :Number = 540;
      public const ZOOM_STEP :Number = 0.25;
      public const ZOOM_MAX :Number = 2;
      public var ZOOM_MIN :Number = 0.1;
      protected varstartPoint : Point;
      protected var scrolled : Boolean = false;
      protected varcurrentZoom :Number = 1;
      public function getgetZoom () :Number { returncurrentZoom; }
      protected varZoomSize :Point;
      protected varorigPos :Point;
      // Mouse pos in glade while scrolling, or null if not scrolling
      protected varscrollPos :Point;
      protected varprevScrollPos:Point;
      protected varorigScrollPos :Point;
      private varstageScale:Number;
      private varoffsetX:Number;
      private varbottomPanelHeight:Number;
      private varready : Boolean;
      private var image:Bitmap;
      public function Screen() {
      ready =
      false;
      var loader:Loader = new Loader;
      loader.contentLoaderInfo.addEventListener(Event.COMPLETE, imageLoaded);
      loader.load(
      newURLRequest("Assets/pic.JPG"));
      FlexGlobals.topLevelApplication.log_msg(
      "started loading");
      addEventListener(Event.ADDED_TO_STAGE, init);
      addEventListener(Event.REMOVED_FROM_STAGE, uninit);
      private functionimageLoaded(event:Event):void
      image =
      newBitmap(event.target.content.bitmapData);
      this.addChild(image);
      protected functioninit(event : Event):void
      origPos =
      new Point(0,0);
      startPoint =
      new Point(0,0);
      removeEventListener(Event.ADDED_TO_STAGE, init);
      addEventListener(MouseEvent.MOUSE_DOWN, startScroll);
      protected functionuninit(event : Event):void
      removeEventListener(Event.REMOVED_FROM_STAGE, uninit);
      private functiongetRealZoom () :Number
      varzoom :Number = Math.min(ZOOM_MAX, Math.max(getMinZoom(), currentZoom));
      //FlexGlobals.topLevelApplication.log_msg ("getReal zoom " + zoom + " bg width " + bg.width + " h " + bg.height);
      ZoomSize =
      new Point (image.width * zoom, image.height * zoom);
      return zoom;
      public functionsetCurrentZoom(gladeCurrentZoom:Number):void
      //FlexGlobals.topLevelApplication.log_msg ("set current zoom " + gladeCurrentZoom);
      currentZoom = gladeCurrentZoom;
      setZoom();
      // Apply zoom (absolute, not relative to current)
      public functionsetZoom () :void
      varzoom :Number = getRealZoom();
      //FlexGlobals.topLevelApplication.log_msg ("setZoom zoom " + zoom);
      // Center
      if (zoom == 1)
      this.x = origPos.x + offsetX;
      this.y = origPos.y;
      else
      // scaleX (or Y) is old zoom
      //FlexGlobals.topLevelApplication.log_msg ("set Zoom before scaleX " + scaleX + " zoom " + zoom + " this.x " + this.x + " y " + this.y);
      var screen_height:Number;
      varfactor :Number = (scaleX - zoom) / 2;
      //FlexGlobals.topLevelApplication.log_msg ("factor " + factor);
      this.x = Math.floor(Math.max(Math.min(this.x + SCREEN_WIDTH * factor, origPos.x), SCREEN_WIDTH - ZoomSize.x));
      this.y = Math.floor(Math.max(Math.min(this.y + SCREEN_HEIGHT * factor, origPos.y), SCREEN_HEIGHT - ZoomSize.y));
      // Change
      scaleX = scaleY = zoom;
      "set Zoom after scaleX "+ scaleX + " this.x " + this.x + " y " + this.y);
      public functionzoomIn () :void
      //if (this.stage.displayState == StageDisplayState.FULL_SCREEN)
      //return;
      if(currentZoom >= ZOOM_MAX - 0.0001)
      return;
      currentZoom = Math.min(currentZoom += ZOOM_STEP, ZOOM_MAX);
      setZoom();
      //FlexGlobals.topLevelApplication.log_msg ("zoomIn " + currentZoom);
      public functionzoomOut () :void
      //return;
      //if (this is Glade) SoftTutorial.instance.validateTask(SoftTutorial.ZOOM_GLADE);
      if(currentZoom <= getMinZoom() + 0.0001)
      return;
      currentZoom = Math.max(currentZoom -= ZOOM_STEP, getMinZoom());
      setZoom();
      //FlexGlobals.topLevelApplication.log_msg ("zoomOut " + currentZoom);
      public functionstartScroll (e :MouseEvent = null) :void
      //FlexGlobals.topLevelApplication.log_msg ("start scroll mousX " + mouseX + " y " + mouseY + " stageX " + stage.mouseX + " y " + stage.mouseY + " parentX " + parent.mouseX + " y " + parent.mouseY);
      if(ZoomSize == null)
      getRealZoom();
      // The mouse position relative to forest/glade
      varglobpt :Point;
      if (this.stage.displayState == StageDisplayState.FULL_SCREEN){
      globpt = localToGlobal(
      newPoint (mouseX, mouseY));
      scrollPos = stage.globalToLocal(globpt);
      stageScale = FlexGlobals.topLevelApplication.fullScreenScale;
      else{
      scrollPos = parent.globalToLocal(globpt);
      origScrollPos =
      new Point (this.x, this.y);
      prevScrollPos = origScrollPos;
      if(!hasEventListener(MouseEvent.MOUSE_MOVE))
      addEventListener(MouseEvent.MOUSE_MOVE, scrollMouseMove);
      addEventListener(MouseEvent.MOUSE_UP, stopAllDrags);
      removeEventListener(MouseEvent.MOUSE_DOWN,startScroll);
      private functionstopAllDrags(event : MouseEvent = null):void
      stopDrag();
      removeEventListener(MouseEvent.MOUSE_MOVE, scrollMouseMove);
      removeEventListener(MouseEvent.MOUSE_UP,stopAllDrags);
      addEventListener(MouseEvent.MOUSE_DOWN,startScroll);
      private functionstopScroll (e :MouseEvent = null) :void
      //FlexGlobals.topLevelApplication.log_msg ("stop scroll scrollPos x " + this.x + " y " + this.y);
      if(hasEventListener(MouseEvent.MOUSE_MOVE))
      scrollPos =
      null;
      scrolled =
      false;
      public functiontoggleGladeSize(s:Number,bottom_panel_height:Number):void
      if(s == 1)
      // back to normal mode if y under -277 adjust it back
      if (this.y < (SCREEN_HEIGHT - this.height))
      this.y = (SCREEN_HEIGHT - this.height);
      else
      stageScale = s;
      bottomPanelHeight = bottom_panel_height;
      public functionscrollMouseMove (event :MouseEvent) :void
      var_stageScale:Number;
      if(scrollPos != null)
      varnewX:Number = origScrollPos.x + stage.mouseX - scrollPos.x;
      varmarginX:Number;
      //FlexGlobals.topLevelApplication.log_msg ("FlexGlobals.topLevelApplication.log_msg this.x " + this.x + " width " + this.width + " stage " + this.stage.width + " stage fullScreenWidth " + this.stage.fullScreenWidth);
      _stageScale = stageScale;
      marginX = ((stage.fullScreenWidth - (image.width*_stageScale))/_stageScale);
      //marginX = GLADE_SCREEN_WIDTH - bg.width;
      "new X "+ newX + "margin X "+marginX + " stageScale "+ _stageScale );
      "image.width "+image.width + " stage.fullScreenWidth " + stage.fullScreenWidth);
      if(newX > 0){
      this.x = 0;
      else if(newX < marginX){
      this.x = marginX;
      else{
      this.x = newX;
      varnewY:Number = (origScrollPos.y + stage.mouseY - scrollPos.y);
      var _x:Number=this.x*currentZoom;
      varmarginY:Number;
      marginY = ((stage.fullScreenHeight - (image.height*_stageScale))/_stageScale);
      "stage.fullScreenHeight "+ stage.fullScreenHeight + " image.height " + image.height + " newY "+ newY + " marginY " +marginY);
      "newY "+ newY + " marginY "+ marginY + " currentZoom "+ currentZoom + " realzoom "+ getRealZoom() + " gladeZoomSize.y " + ZoomSize.y);
      if(newY > 0)
      this.y = 0;
      else
      if(newY < marginY)
      this.y = marginY;
      else
      this.y = newY;//origScrollPos.y + parent.mouseY - scrollPos.y ;
      var_y:Number=this.y;
      else
      varminX:Number;
      if((origScrollPos.x + parent.mouseX - scrollPos.x < origPos.x + startPoint.x))
      minX = origScrollPos.x + parent.mouseX - scrollPos.x;
      else
      minX = origPos.x + startPoint.x;
      if(minX > origPos.x - (ZoomSize.x - SCREEN_WIDTH) + startPoint.x)
      this.x = minX;
      else
      this.x = origPos.x - (ZoomSize.x - SCREEN_WIDTH) + startPoint.x;
      varminY:Number;
      if(origScrollPos.y + parent.mouseY - scrollPos.y < origPos.y + startPoint.y)
      minY = origScrollPos.y + parent.mouseY - scrollPos.y;
      else
      minY = origPos.y + startPoint.y;
      if(minY > origPos.y - (ZoomSize.y - SCREEN_HEIGHT) + startPoint.y)
      this.y = minY;
      else
      this.y = origPos.y - (ZoomSize.y - SCREEN_HEIGHT) + startPoint.y;
      "normal min x "+ minX + " minY "+ minY + " this.x " + this.x + " this.y " + this.y);
      // Change now, dont wait till next frame
      scrolled =
      true;
      event.updateAfterEvent();
      private functiongetMinZoom() : Number {
      if (image.width > 0)
      //if (this.stage.displayState == StageDisplayState.FULL_SCREEN){
      //return Math.max(ZOOM_MIN, GLADE_SCREEN_WIDTH / bg.width, stage.fullScreenHeight / bg.height);
      //} else
      return Math.max(ZOOM_MIN, SCREEN_WIDTH / image.width, SCREEN_HEIGHT / image.height);
      else
      return ZOOM_MIN;
      public functionisReady() : Boolean {
      return ready;
      private functionassetsLoaded() : void {
      ready =
      true;
      dispatchEvent(
      new Event(Event.COMPLETE));
      Thanks for helping
      Elisheva
