0 Replies Latest reply on Mar 29, 2011 12:52 PM by crazycabo
    Manually changing datagrid values, then verifying with a function..
    crazycabo
      I am simply trying to verify when a user attempts to change a specific value in one the above cells in a given row. If both are = or < 4, the change will take affect. If not, I want to run a function to disallow the change to happen, reverting back to the values before the attempt. I tried to use the "itemEditEnd" property, which makes the most sense to me. It does not work as intended though.
      Here is the function I call with the "itemEditEnd" property:
      private function verifyCorrectCardCount():void{
           var item:Object = deckGrid.selectedItem;
           var cardName:String = item.name;
           var cardType:String = item.type;
           var setName:String = item.setname;
           var cardRules:String = item.rules;
           var cardNameFromDeck:String;
           var deckCount:int = item.deckCount;
           var sideCount:int = item.sideCount;
           for (var loop:int = 0; loop < deck.length; loop++) {
                cardNameFromDeck = deck.getItemAt(loop).name;
                if (cardName == cardNameFromDeck) {
                     if ((deckCount + sideCount) > 4) {
                          deck.removeItemAt(loop);
                          deck.addItem({name:cardName, type:cardType, setname:setName, rules:cardRules, deckCount:deckCountCheck, sideCount:sideCountCheck});
                     }else {
                     return;
      Note: deckGrid is an arrayCollection used by the dataGrid above.
      Maybe timing is the issue. I'm still don't know how all of the dataGrid properties and dispatchers work.
