1. Re: I did look first
Stan Jones Mar 29, 2011 5:27 PM (in response to Reese Richardson)I created 11 chapter markers in Encore they all work as a DVD but when I turned the file into a Flash only the first chapter marker worked and the last worked everthing checked as for error before I built.
What do you mean by the first and last worked? They played? Or the chapter advance button moved to the next chapter?
2. Re: I did look first
Reese Richardson Mar 29, 2011 5:37 PM (in response to Stan Jones)Yes the first chapter and the eleventh played the other nine did nothing they just froze. In the DVD version all chapters worked as intended.
The only thing I can surmise from this is Flash doesn't work this way I've never tried it before now.
3. Re: I did look first
Stan Jones Mar 29, 2011 5:52 PM (in response to Reese Richardson)My experience is that it works fine.
Did you test it locally?
4. Re: I did look first
Reese Richardson Mar 29, 2011 6:03 PM (in response to Stan Jones)Yep I created the files and the two flash files didn't work I don't know. I learn most of this by trying and trying again. It didn't make any sense that it won't work.don't know what else to do to it. Anyway the DVD works and that what I need right now. So I'm going to leave it alone for a bit Thanks though
