3 Replies Latest reply on Mar 31, 2011 6:34 AM by mick.powell
    Air 2.0 Native process not working
    l33tian Level 1
      Hi Guys
      I'm trying to write an AIR pplication that responds to a Generic Game controller. I used java's Jinput to poll the controllers buttons then send the output to the standard output stream. then i bundled the jar files and the appliccation assets into a .exe file...which works just fine
      after doing all the normal native process rituals - instantiating nativeprocessstartupinfo and native process class, setting the executable path, adding eventlisteners for the native process and calling the start method, it doesnt seeem to give me any ouput
      Here is snipppet my code
      if(NativeProcess.isSupported)
           Alert.show("native process is supported!")
           // TODO Auto-generated method stub
           var flApp:File=new File("FLController/FansleagueController.exe")
           inputProcess=new NativeProcess();
           inputProcessInfo=new NativeProcessStartupInfo();
           inputProcessInfo.executable = flApp;
           inputProcessInfo.workingDirectory=File.applicationDirectory;
      if(flApp.exists)
           Alert.show("Controller Mediator Application(fansleagueController.exe) Found!");
      else
           Alert.show("Controller Mediator Application(fansleagueController.exe) could not start!");
           inputProcess.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA, onOutputData);
           inputProcess.start(inputProcessInfo);
      else
           Alert.show("Native process is not supported in this environment, make sure the extendedDesktop *** was selected in the Application descriptor");
